Calamity - 30 Watt with Precision
Calamity amplifier
features
  • Power Supply 2x20VAC transformer ~ +/-27VDC
  • Bootstrapped VAS stage
  • Transitional Miller Compensation, TMC
  • Output more than 30 Watt into 8 Ohm
  • Precision = THD 0.00004% at 1 Watt
Reactions: lineup
Nico
Can I ask what size and voltage your power supply transformer was?
Calamity uses 2x20VAC transformer rated 200-300 VA for stereo.
It is class AB with 200 mA bias.
I post my circuit again for newcomers.
THD is 0.000004% in simulation.
The squarewave is 10 kHz.
If one is building amps with one P fet and one N fet output per channel (as in many of Lineup's interesting recent concepts), there is little need for paying extra for the 'S' 'matched' ones from Profusion. The close-binned 'S' items (they are aligned by same part only, not across NPN/PNP) would be a good idea if there were multiple same-part output fets per channel. No harm in paying extra if one desires, however.
Reactions: mz543578854 and stv
