Power Amp burning smell
I have a Counterpoint solid state power amplifier which I have been using since a year with my B&W 805 matrix speakers. This morning I changed my preamp to a Schiit Valhalla 2 Tube preamp and everything played well as usual. When I turned on my system this evening, both speakers were whining like a burglar alarm and I immediately switched off the power amp to be safe. There was a burning smell from the power amp for sure like some thing went wrong and the power amp has a 6 Amp 3Ag fuse for each channel next to the banana terminals. Upon observing, one fuse of the left channel had blown. I am reluctant to switch on the power amp again as I'm afraid if the speakers may get damaged.
Please advise what I can do to fix this and also is it possible for something from the Tube preamp pass through the attached rca interconnects and has caused this?
Thank you
I see a resistor that's had a really bad day:
Did the outputs get shorted while changing source?
No. It was playing well till I switched it off this noon. Then when I switched it back on this evening, the whining started from the speakers quite loud and the power amp started to give a burning smell. I switched off the power switch immediately and waited for 2 mins and switched it back on to see if it has stopped but it was still whining and the smell got more. I switched it off and unplugged it to check and saw the above.
The semiconductors connected directly with the damaged resistors are very likely damaged. With the help of a multimeter in diode mode and resistance mode you can determine which semiconductors are damaged. Damage very often manifests itself as a short.
Since the amplifier is damaged I suggest you use a series filament bulb. The purpose is to have a low series resistance in the case there is no damage and a high series resistance if the amplifier is faulty. Look up series bulb amplifier test.
I have a question. If the problem were to be identified and required soldering, would you be able to do this? Do you have knowledge of circuitry and experience? This is not 'replace the fuse and all is well'. Something bad happened and it will be an involved measure to find the problem.
Just as important will be to find a qualified repair shop!
