Hi all, i have a load of old woofers sitting around and ive been studing hornresp for a few weeks now, issue i have is that my subs appear to be cookie cutter chineseium and are missing a bunch of the parameters needed for hornresp.
I have a DATSV3 and that, also, doesnt give me the parameters i need.
My question is, given that ive designed a horn that im reasonably happy with (96-100db from 26-80hz), is this planned response then irrelevant without the driver parameters, or will be be close, but not accurate?
I have the SD and the LE from the dats, but virtually nothing else and i need SD, BL, CMS, RMS, MMD, LE, RE.
Thanks in advance,
Adam,
Thanks in advance,
Adam,
it should give you all parameters you need.I have a DATSV3 and that, also, doesnt give me the parameters i need.
Make sure you really know how to use it correctly, including added mass/test enclosure measurement.
