Do the 3C24/35T sound any good at less than half their rated anode dispersion?
I read here some peeps running 3c24 at 400V / 15ma - less than half of the rated anode dispersion...would these tubes:
1. Sound any good there?
2. Live very long there?
3. Be all good
1. not lightly as power amplifier
2. yes
3. Not
this is power DH triode. Ususaly run as A2 class with grid current.
3C24 has very high Ri, and needs good output transformer with high primary inductance to have close to decent bass... 🙁
As preamplifierm it could be used BUT then high amplification factor of about 25 could be the problem. Because sources has about 2Vrms outputs, that is about 6Vp-p to the grid of 3C24.
In that case -3V is minimum value for the bias point...
Again High output resistance of about 10K ohms from preamp because of high Ri. maybe it is too week to drive alone next stage?
And 6vp-p x 25 = 150Vp-p on the output of preamp when pot is in max with 2Vrms input...
As a driver, again high output resitance could be the issue to drive next input capacitances...
here are the spice models based on diy audio members. Could be useful for further steps?
2 spice models are in code window, one model for DHT and same for classic triode.
cheers
Code:
****  ** Composite DHT with Advanced Grid Current **************
* Created on 07/18/2024 10:05 using paint_kit.jar 3.1
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file: /Users/zoran/Desktop/Model_Paint_Tools/Graph/
* Data source link:
.SUBCKT 3C24_DHT 1 2 3 4 ; P G K1 K2
+ PARAMS: CCG=2.8P  CGP=2.1P CCP=1P RFIL=2.1
+ MU=26 KG1=7038.69 KP=200 KVB=1140 VCT=-1.25 EX=1.53
+ VGOFF=-1.772 IGA=0.0025 IGB=0.0935 IGC=0.35 IGEX=1.823
* Vp_MAX=600 Ip_MAX=27 Vg_step=0.5 Vg_start=0 Vg_count=11
* Rp=30000 Vg_ac=3 P_max=25 Vg_qui=-3 Vp_qui=400
* X_MIN=77 Y_MIN=119 X_SIZE=645 Y_SIZE=742 FSZ_X=1573 FSZ_Y=978 XYGrid=true
* showLoadLine=y showIp=y isDHT=y isPP=n isAsymPP=n showDissipLimit=y
* showIg1=y gridLevel2=y isInputSnapped=n
* XYProjections=y harmonicPlot=y dissipPlot=y
RFIL_LEFT    3  31 {RFIL/4}
RFIL_RIGHT   4  41 {RFIL/4}
RFIL_MIDDLE1 31 34 {RFIL/4}
RFIL_MIDDLE2 34 41 {RFIL/4}
E11 32 0  VALUE={V(1,31)/KP*LOG(1+EXP(KP*(1/MU+V(2,31)/SQRT(KVB+V(1,31)*V(1,31)))))}
E12 42 0  VALUE={V(1,41)/KP*LOG(1+EXP(KP*(1/MU+V(2,41)/SQRT(KVB+V(1,41)*V(1,41)))))}
RE11 34 0 1G
G11 1 31 VALUE={(PWR(V(32),EX)+PWRS(V(32),EX))/(2*KG1)}
G12 1 41 VALUE={(PWR(V(42),EX)+PWRS(V(42),EX))/(2*KG1)}
RCP1 1 34 1G
C1 2 34 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 34 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC1 81 0 VALUE={V(2,31)-VGOFF} ; POSITIVE GRID THRESHOLD
GG1 2 31 VALUE={0.5*(IGA+IGB/(IGC+V(1,31)))*(MU/KG1)*(PWR(V(81),IGEX)+PWRS(V(81),IGEX))}
EGC2 82 0 VALUE={V(2,41)-VGOFF} ; POSITIVE GRID THRESHOLD
GG2 2 41 VALUE={0.5*(IGA+IGB/(IGC+V(1,41)))*(MU/KG1)*(PWR(V(82),IGEX)+PWRS(V(82),IGEX))}
.ENDS 3C24_DHT
****  ** Advanced Grid Current **********************************
* Created on 07/18/2024 10:06 using paint_kit.jar 3.1
* Data source link:
.SUBCKT 3C24 1 2 3 ; Plate Grid Cathode
* showLoadLine=y showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C3 1 3 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC 8 0 VALUE={V(2,3)-VGOFF} ; POSITIVE GRID THRESHOLD
GG 2 3 VALUE={(IGA+IGB/(IGC+V(1,3)))*(MU/KG1)*(PWR(V(8),IGEX)+PWRS(V(8),IGEX))}
.ENDS 3C24
For positive grid current You can use this models for 3C24
Code:
* Created on 07/18/2024 09:45 using paint_kit.jar 3.1
* Data source link:
.SUBCKT DHT__A2 1 2 3 4 ; P G K1 K2
+ MU=22.77 KG1=7650.75 KP=1500 KVB=1140 VCT=0.05 EX=1.515
* Vp_MAX=700 Ip_MAX=250 Vg_step=10 Vg_start=100 Vg_count=13
* Rp=4000 Vg_ac=55 P_max=25 Vg_qui=-50 Vp_qui=300
* X_MIN=85 Y_MIN=103 X_SIZE=516 Y_SIZE=613 FSZ_X=1701 FSZ_Y=852 XYGrid=true
RE11 34 0 1G
RCP1 1 34 1G
RE2 2 0 1G
.ENDS
* Data source link:
.SUBCKT TRIODE_ 1 2 3 ; Plate Grid Cathode
RE2 2 0 1G
.ENDS
Reactions: toshiba_nz
