Any info on Vintage 1970s Linear T40/60 MK1 Amplifier?
If my research is correct, the Fane speaker is a Pulsonic 122301:
Hi and thanks!
I would certainly appreciate photos of the amplifier interior in order to view the workmanship.
I'd also be interested in knowing which model of Fane speaker is present in the Linear cab.
Find attached some photos of the inside.
I know you previously doubted the workmanship but for early to mid-1970s, it’s certainly survived the toll of time.
You are correct it’s a Fane 122301.
  • Thank You
Reactions: Galu
Thanks for the pics!
I actually never doubted the workmanship.
As @budkor himself said: "This is a beautifully made classic transistor amp. The power supply is beefy, and the capacitors are massive. It has the classic audio transistors on board, which are clean and tidy design."
