Rotel RB985 Noise floor problem?
I recently got a used RB985 on the cheap and trying to make it perform. I have an issue that I have not come across before and am hoping for some ideas or pointers what might be going on.
The odd thing is that the noise changes with what signal cable I use and with the cable disconnected it's "silent".
Adding a pic of how it looks on REW and a Focusrite G3. Red is the signal cable disconnected and green with it connected to the preamp muted and I have obviously tested with other amps, in this case the Rotel RB 980 and with that there is no difference with the cable disconnected or not.
All channels and a buzz, as the the FFT shows it seems to be rich mains harmonics.
Thanks for the link but I have that schematic already and its not fully accurate so if anyone has another version it would also be very helpful.
If you have cable connected at amp but floating at the source end, is hum still present? What if you short shield to center conductor, but unconnected to source? If you grasp cable, does hum increase?
i.e. what madis64 just said! 😀
How are the preamp and power amp chassis grounded?
The power amp now has a very solid (6mm2) star ground with a 2.2ohm and 0.1 uF in parallel connected to the casing. My goto has been how it was grounded and I have reworked it getting the noise much lower but it seems I cant get it lower with any additional ground changes I can come up with.
The preamp has performed flawlessly in this respect, so far supporting maybe 20 amps and as I said it's the same connected directly to a Topping D70 DAC.
Have the preamp and poweramp chassis been connected by a dedicated wire?
No and I just now tested a direct connection between the chassis but it did not change anything.
But with the questions I decided to disconnected the left input while measuring the "still" connected right input and the right output was clean which indeed indicates a ground loop type of issue?
But that may be caused by the physical layout and connections of signal path components but we have no photos...
Happy to provide photos but the signal input layout is very straight forward now, shielded cable from the connector directly to the pcb and the pcb layout is "std" rotel as compared to the RB 980 and many others. There is one power ground point for each the two left and right channels with a solid connection to the star ground and center tap on the trafo.
That said there is obviously a problem and maybe it will help adding a small resistance (2 ohm'ish) between signal and power ground?
