Pluvia 7.2 HD triple reflex series chamber loudspeaker
I’ve ordered my Pluvia 7.2 HD drivers and came across an interesting speaker design. Does the design seem viable? Has anyone built it?
Why would it be 'unlikely'? Since it's 0319 and I'm on my laptop, I'll have to post the FR tomorrow, as it's on my desktop machine. As noted, it's been quite popular with some builders in Japan.
These things are not just pulled out of the air; the fact that I don't post full measurements of every single design I create doesn't mean they don't exist -it means that muggins here unfortunately doesn't have an infinity of time. If I got into that game, I'd be here (and everywhere else, probably) until the next flood happens. 😉
Perhaps unlikely was unfair phrasing - what I really mean is, resources such as FR charts are not always easily found or able to sourced without explicitly asking for them, or knowing who to ask! And I should speak for myself, not others; the personal experiment of trying a design without really knowing precisely what to expect from its sound - and just being excited about a design, not a chart - is what's fun. I think many would relate to this 🙂
Reactions: GM and Scottmoose
For a project with smaller fullrange / wideband drivers.
The tower form factor seems like the more ideal shape
to just have fun.
The extra space you get from going tall.
Is just asking to have a multi chamber port.
Might as well have fun with the space.
Go for it.
Gives room for being creative with final finish too.
Port has been designed already.
Saves some time, all the works been done.
far as maths and measure.
Reactions: GM and marc brown
No, I agree (not unfair at all) -I understand where you're coming from, & you're right, it can be a challenge (or a leap of faith 😉 ) if data isn't posted. Sorry I couldn't add earlier but been out most of the day. This is the quick one from Omnimic I took, 6ms window IIRC. Excuse the graph scale; I've got more detailed plots elsewhere with nearfield hard spliced in that look a bit prettier too, but will need to dig them out of the records & this should give an idea of the general trending.
Below 150 Hz is impressive flat and very deep for a small fullrange!
Is that dip around 200 Hz coming from the enclosure, or from the room?
Below 150 is a result of that ported, three chamber, series resonance. If you look at the dimensions of the chambers heights: 15”, 10”, 5” with the total chambers height of 30”.
I’m most likely misspeaking a bit but it is pretty “badass”. 😈
No dsp, no eq, just acoustic wizardry. 😉
