Best 12" woofer for open baffle midbass?
That is basically what I´m already doing: I use a nude 18" Faital from 70 to 300Hz, digital XO thru Acourate.
I´m looking to keep the baffle small, around 45cm x 75cm
2* (45+75) = 240 cm
34400/240 = ~143 Hz, setting on, and perpendicular to, the floor lowers it by 0.707x = ~101 Hz
Clayton Shaw uses these Beyma 12BR70 in his new Caladan OB:
"Shaw’s Caladan boasts a 1.5" thick baffle made from kiln-dried, solid American hardwood. It employs twin 12" Beyma pro-audio bass/mid units and a 1 1/8" silk-dome tweeter. Frequency response is said to be 32hz–20khz, ±2db, the sensitivity 93db/W/m, and the nominal impedance 4 ohms. The Caladan stands 38" high by 18" wide by 10" deep, including the legs, and weigh 35lb. Isoacoustics Gaia iii feet are included."
https://www.stereophile.com/content/linear-tube-audioclayton-shaw-acoustic-lab
https://claytonshawacousticlab.com/697-2/
Reactions: decramer
Bianco colored above 200Hz would be a con. I wasn't aware. Thank you!
That's about what you can expect from such an inexpensive driver...
Since you mentioned using two 12" drivers, I will mention that in some of my own OB designs I have used four 8" drivers. This makes for a nice compact and square bass section. The 8" driver will not have issues like cone breakup or surround resonances, etc. in a passband that goes up to 400Hz. Using four you can wire series-parallel or even all in parallel for higher voltage sensitivity. Four 8" drivers with 5mm Xmax can operate down to and crossed over at e.g. 70Hz with pretty high SPL (for home audio) even when the baffle is not large. Even a relatively cheap 8" will not have issues below 400Hz...
Maybe this is an option you would consider?
Reactions: ianbo
That speaker will have a very F-d up power response. Crossing a 12" to a monopole 1" ish dome tweeter is not typically recommended because the radiation pattern will grow narrow just below and then widen to almost monopole above, the crossover point. I'm not seeing anything to "boast" about here...
I´m trying to solve the midbass sound first. Hopefully in OB, or maybe I need to move to sealed.
Your system has too much drivers ... Four way is a problem to tune, and you want to go to five ways ?
I think with only three ways you can do something sounding good.
You don't need a 12" for the midbass, the 8" can do well the job. You have to equalize actively the 8" to use it in the range 130Hz-1300Hz LR4 slope recommended The anemic mid-bass is a bad equalization or a negative effect of other drivers. The equalization depends on the baffle size.
Note add a second 8" as suggested could be done 😉
And the 18" or 4x12" covers the bass 20-130Hz. Keep thing simple.
I was already done this kind of system with an analog passive crossover and the result is stunning. Do not forget to align acoustic centers 🙂
I havent heard the speaker but apparently plenty of good reviews...I was just putting it as an example. Maybe they do sound weird...
Historically driver Qt = desired transient response = Qtc, so 0.5/transient perfect - 0.707/max flat
For a sealed enclosure loudspeaker (by definition, though terms are sort of misnomers):
Q < 0.5........Over damped...........No overshoot to rest position after a step input, extended settling time, tapered low frequency response
Q = 0.5........Critically damped......No overshoot to rest position after a step input, minimum settling time without overshoot (not perfect transient response)
Q > 0.5........Under damped..........Overshoot to rest position after a step input
Q = 0.577.....Bessel Function.........Very slight overshoot to rest position after a step input, minimum settling time
Q = 0.71......Butterworth Function..Slight overshoot to rest position after a step input, lowest flat frequency response
And to make things a little more complicated:
https://www.geocities.ws/kreskovs/Box-Q.html
Reactions: GM
Well, this is a bit of a puzzle. I can't see any reason why the Faital 18HP1010 should be a failure in this application. But unless you've worked out what the problem with it is, you risk spening money and not fixing anything.
Can you share your equalisation/crossover on the Faital? Or for whole setup?
2* (45+75) = 240 cm
what does this number/calculation represent?
Yes, I would consider this. I do have 4x 8PE21 but these aren´t woofers but midranges. Not enough Xmax. Which 8" drivers have worked well for you in OB and having good midrange into 400Hz?
@ianbo , @lousymusician
Will get my measurements with Acourate and the correction applied. It´s a bit cumbersome because it´s in a computer I rarely use and need to bend over backwards to get it up and running. Hopefully I can get it done tonight. Otherwise tomorrow night.
Makes total sense to first figure out what is causing this, if you can help me from reading graphs.
Thank you!
Reactions: ianbo
Some of the cheaper Visaton drivers are nice in OB. The W300 is a good 12 for OB. Eminence Delta Pro 15A and the Deltalite 2512 are good sounding 15s. Newark has some cheap cast frame pro drivers which also sound good for higher Q applications
Someone mentioned the Beta8 for a mid. I fully endorse that driver. Its a hidden gem. Beautiful midrange. Likely the best pro mid under $100.
Reactions: GM
Some measurements from when I developed the filters in Acourate.
First graph shows left and right sweep measurements using the digital xo, also the target curve against which the speaker response is hammered into shape:
You can see the massive drop of the 18" starting around 280Hz.
These are the xo:
Sorry for the picture quality and size...couldn't format well on Android.
I understood, sure your crossover is not working ! You don't have any open baffle equalization .... Sure you don't have any low mid and you can better with less.
This an example of crossover I done. I include the dipole equalization and delay correction.
With your numeric crossover you should do the same crossover response.
Bass correction is red curve - Green is mid curve and blue is tweeter curve : the only normal curve without dipole correction. The mid curve is a little more complex du to mid-bass correction.
To make dipole correction you should take into account the dimension of the baffle. Here the baffle is 30 cm wide, a dipole equalization 20-400Hz is done.
Note you can do a global dipole equalization (see Perry Marshall designs ) or for each drivers.
The last time I used the 4x 8" drivers I used a Peerless HDS 8" woofer but they are no longer available. You could for example use the new Dayton 8" SIG225, which has some similarities to the Peerless driver and would perform well below 400Hz. I would definitely use a home audio 8" and not a pro audio driver in this case. I'm not sure what brands are available where you live, or I would give you some more recommendations.
@LewinskiH01 Thanks for sharing the pictures. Have I got this right: the first photo shows a sweep of L and R channels, each with all drivers playing. Acourate is crossing over between drivers, but no further equalisation has been applied. Is that correct? I assume that for listening, you apply a further equalisation filter to this response, to force it to fit the target curve - but that equalisation curve isn't shown. Correct?
You mention that you can see the Faital 18 dropping off below 280 Hz or so. Yes, you can. And that's exactly what you'd expect it to do, uncorrected, on a small baffle or playing nude.
The second photo shows crossover filters. Again, these don't look as if they include equalisation to fit the driver responses to a target curve.
I may be misunderstanding you, but if you are playing the system using the filters shown in the second photo, and no further equalisation, then you will be getting the response shown in the first photo. And that doesn't include any equalisation of the Faital for the open baffle loss (as Jerome69 said). That would certainly cause anaemic mid-bass. But maybe you do indeed have a further layer of equalisation, fitting the response to the target curve, but not shown in the photos?
@ianbo
Yes, correct. Those sweeps are with all xo applied, all drivers/amps playing in their passband but without any equalization. Different amp/driver sensitivities/gains also explain why some shoot up so high. Those sweeps have psychoacoustic smoothing applied, a standard initial step when working with Acourate. A next step is designing the target response curve, also shown on the first picture. Then come a few steps that force the speaker response to be the same as the target curve. I could show that, but I doubt it will tell us much because it is essentially the same as the target curve. The equalization curve would be the mirror image of the sweep above the target curve.
BTW, the target curve is essentially down to compensate for the large drop around 300Hz at the 18", since Acourate won´t correct the sweep below the target curve.
Partially correct: The subs don´t show correction because I use Multi Sub Optimizer at a MiniDSP that distributes to the 4 subs. The tweeter XO is not shown in the picture, but you can see the midbass and midrange XO have wiggles that are corrections from a linearization done on Acourate before the final measurement/correction. So these show a partial correction, but not the whole thing.
Indeed, there is a final layer of "equalization". Not sure how to show this in a way that would be constructive here. Graphing the FIR filters would look messy. If I applied smoothing to them then they wouldn´t really show what they are doing. If I show the corrected final response it would look pretty much like the target curve.
Reactions: Juhazi and ianbo
OK, I see. I'm now stumped, I'm afraid.
Maybe the Faitals just aren't right for this system, although I honestly can't see why that should be so.
But another possibility is that something in your measuring/equalising/playing chain is off. It's a very complex system, after all: miniDSP and Acourate, multi subs plus 3 way OB, with a range of different power amps. Getting all that to work together properly is a huge challenge! Sometimes with this type of setup you correct things that you ought not to be correcting, and get inferior results as a consequence. I've been there! Measuring open baffles accurately is particularly challenging, of course.
I'm actually moving away from DSP, in my own system, because of this type of problem. I've tried DSP-based systems repeatedly over twenty years, going right back to early Tact, then Lyngdorf, then PC based systems, and more recently DEQX. Time after time, I struggled to get the results I thought I should, and because of the complex nature of the process and the software/hardware, I always found it very difficult to work out the reasons.
Anyway, I apologise for the pessimism. I know that plenty of other people have success, and of course DSP is increasingly the norm, especially in pro audio. I've not totally given up - I still have some miniDSP and Hypex Fusion hardware, which I may use for bass/subs, at some point.
Sorry, I wish I could help more.
