Fixing holes
I have managed to put a hole in my Jordan Watts module speaker cone. The hole is the size of a split pea near the edge of the cone. Is there a solution? I also must add that I think these very old modules need re centring, Thank you for any suggestions.
Laszlo.
Not everyone will be familiar with those modules.
It's a metal cone. If the hole is tiny just fill it with a clear sealant like this: https://www.halfords.com/motoring/p...LS*MTcxMzg5ODI4MS4xLjAuMTcxMzg5ODI4MS4wLjAuMA..
If the modules have hung vertically for years with the same orientation, then it's time to rotate them 180 degrees and hope that gravity will recenter them.
Reactions: JMFahey
Thankyou for your advice! I have turned my dipoles using these speakers upside down and I shall be buying some sealant. The hole is 1/8 x2/8ths
Reactions: Galu
That sounds suspiciously flat screwdriver blade size to me! 😳
I've been researching these modules and, for the record, will supply some information regarding their rear suspension.
Instead of the usual spider, the voice coil is suspended on three Beryllium cantilevers, two of which carry the signal to the voice coil.
The 3 wire cantilevers can clearly be seen in attached image (courtesy of @woody) where the cone has been removed - not an action I advise you to do!
Read about the modules here: https://www.drmarksays.com/category/the-jordan-watts-loudspeaker-company/
Reactions: ianbo
