It would be nice to be able to change all the sizes s4 and s5 individualy tho that probably is a lot of work for you.
Isn't there a way in hornresp to simulate stacking 2 boxes on top of each other? This would be different then adding another speaker in series or parallel right? That part would be showing you the sim for 2 drivers in the same enclosure?
What are you doing to cause this caution to be generated? Please be specific, thanks.When it says caution s2 is lower than sd, what problem or effect i guess is that having?
I'm not sure what you're doing, but I'm not getting the same results when I checked my BOXPLAN sheets. Are you using the "Export!" feature in the BOXPLAN sheet to export the corresponding Hornresp sim from the BOXPLAN sheet, and then using Hornresp's "Import" feature to import the sim?Brian this would be on any of the tapped horn boxplans when I important it into hornresp I have change the throat chamber size down to zero to get accurate results. Where does it pull those sizes from and should they be at zero?
That's because there's only one optimal solution for S1 and a box of given external dimensions. If you try to change S2 and S3 and then use the Optimize feature, BOXPLAN will change them back to the values for the optimal solution.Also another question specifically pertaining to the othorn boxplans so even tho it only shows that you can change s1 you can change s2,s3 etc. however when u go this it will not change in the picture of the box layout. Is there anyway to make s2 and s3 able to insert sizes and show in the picture?
If you want to change S2, S3, etc, then the way to do it is to change the box dimensions, or change S1, then select Optimize.
After I import the boxplan into hornresp it then adds dimensions to vtc and atc. I then zero those out in hornresp to get accurate results. This was a problem I had awhile ago and was I thought u told me that was the solution because hornresp tries to account for the cone volume or something like that. It has been a long time since this issue first happened. It does it on every single box plan.
I thought maybe there was a way to be able to change a s2 or s3 and the plot points change as well?
That's different to the issue you previously mentioned. Some of the BOXPLAN workbooks include "cone compensation" techniques that result in values set for Vtc and Atc. If you zero those out after importing the sims into Hornresp, the results will be LESS accurate.After I import the boxplan into hornresp it then adds dimensions to vtc and atc. I then zero those out in hornresp to get accurate results.
this is what I am getting when importing inito horn resp with the vtc and atc i can not get anything close to a result so i normally zero it. Wouldnt this build be considered as havbing no throat chamber? Or would the area bewteen the driver and entry be considered the throat chamber, in this case a 3/4 board?
The sim created by the BOXPLAN workbook tries to include the impact of volume of air in front of the cone by using Vtc and Atc to approximate the effect with a small throat chamber. The results it predicts will be more accurate if this is included. However, you need to ensure that the value for "Cone Volume" in the BOXPLAN workbook (on the "Driver" sheet) is correct. A value of 884 L is definitely incorrect - that's 31 cu.ft.!
i got the number more closely correct snd this is wha i get after importing it. the vtc still seems way to high. I take it that the atc is just the same as the sd of the driver? what is it using to get the number fo vtc?
That value for Cone Volume is still way too high. For a 21" driver, Cone Volume would be more like 9 L.
Ya my measure was in in3 not liters im an idiot lol when I get back to my computer I shall continue on.
32.80cm + 20.40cm = 53.20cm / 2.54cm = 20.84in.
The frame width shows 21.50in.
Good catch. My earlier BOXPLAN workbooks didn't have built-in checks to see if the driver could fit in the box. The later ones do.
after siming it lkike this do you normally take this as ur result or do you go to other and click the pmax?
- Subwoofers
- Spreadsheet for Folded Horn Layouts...
