Actually the KSL210 loader is quite OK, pressed steel not plastic, and just before any money saving seems to have kicked in!Your project is interesting, but I don't understand why you want to use the Sony mechanism
The KSL150 is even nicer with a diecast laser diode. There are various types though so you need to use "image search"
The requirement to fit the original aluminium drawer front is a factor that cannot be overstated either.
But since you brought up Sony vs Philips mechanisms 😱😱 it's a really good point, so here's why I've discounted it this time
The VAM1202 is (in my opinion) is just like the slightly later Sony series, a plastic beast 😈 Lets be honest at this point if I were going full Philips it would be CDM4-19 and a rejig of a CD40 (or something)... I actually have a full cd-player kit based on the VAM1202 in a box, I have yet to be motivated enough to house it.
In short it looks like mid 90's Sony, Philips and everyone else got to making CD popular by removing cost 😢 to the point there aren't really any high end mechs, CD-Pro being the last one?
Anyway, I think that with some suitably 3d printed chassis add on's the KSL210 will be just fine. All the mech is doing is reading digital data in packets anyway. (Feel like I leapt on a grenade there 😳)
Andy
The fact is that you should focus on one thing, the mechanics are controlled by a servo board, and the servo board is not easy to find. I would have solved this problem by recreating the servo board for the CDM12xx so I would have solved this problem, also I would have used a Musical Fidelity A3.5 CD player and completely redesigned the boards, boosting the power supply and creating various connection options, including the possibility of connecting a tube card or an external DAC. In this case the CD player firmware is stored on a PIC16F88 and therefore copyable and that's what I did. In practice I created a CD player complete with controller, servo board and various options... everything works very well.
Oooh nice 🙂 very very nice...
The A3.5 is a good looking player too, the proportions just "click" (I have had one, and the A5CD too) I recall the A3.5 had a lot of space in the case. (good for additions)
I agree with your other comments: power supply and on so on. Same destination different route
At this point I'm 75% with TEAC CD-P4000 servo board - this will unfortunately telegraph 'non standard' because of the track grid on the display so still looking and messing with buffers
Andy
Andy
And today I have musings and the classic 'fiddlers nightmare'
CD-P4000 lots of documentation
CD-P4500 nothing!! but looks OK
The CD-P4500 servo board actually looks very similar to the CD-5 but has anyone got a manual? or can even point me at a source.
The P4500 has the clock on the servo board (easy transport) the P4000/Z5000 on the audio board meaning that I have to deal with that up-front, maybe I do anyway - as I said musings
Andy
Andy
Some decisions made!
Teac CD-P4000 / CD-Z5000 are donor (s) easy decision after all. I will likely fumble around with a HDCD DAC board at some point but the Z5000's twin TDA1541A is acceptable.
The main two boards are separated into servo and audio and importantly they are reasonably compact. Mech is the physically identical KSL150 type - but it has the nicer laser IMHO
I made a brace for the mech with an eye to stiffening / damping the steel chassis - see pictures. Slightly smug that it fit first go to be honest, but I'm also aware that if you think everything is going well its a sure sign you've missed something 🙂
This is a dead mech BTW don't panic
For the record the Teac CD-P4500 I mentioned is at least 99% a CD5 in a more standard box. So if you need a service manual for one start there. The only difference is the pitch control on the 'P4500 and light up buttons on the CD-5. Given the complete lack of information of the CD-P4500 that might be a useful nugget.
Andy
Andy
Another bit - Buffers because why not start at the end and work back??
Taking shape - needs dimensioning. It's just a directly coupled buffer stage with some 'sand' in it.
The associated PSU that I still need to look into, will supply the tube heaters in parallel and much more than 24 volts for the B+ supply!!
Andy
Andy
How about something a little more radical on the valve front. An octal version of the MF CDT aka the Frog-eyes CD player.
CD player that I have been looking for for years.How about something a little more radical on the valve front. An octal version of the MF CDT aka the Frog-eyes CD player.
Do you have the diagram ?
Believe me I considered it. Morgan Jones' comments on the loctals did not escape my consciousness 🙂How about something a little more radical on the valve front. An octal version of the MF CDT aka the Frog-eyes CD player.
In the end I went with the known (boring) considered the 5703's / 6112 sub-mini's too even the 7586 Nuvistor - if sockets were a thing.
Maybe a version two...
Andy
Hmm so a small delay.
CD-P4000 and CD-Z5000 share service manual and boards BUT DAC board is NOT interchangeable, this is a shame as cd-p4000 works flawlessly and CD-Z5000 skips like a happy kangaroo. Hope its a hardware / jumpers thing but worst case its a firmware problem. Might end up CD-P4500 here after all
this is not a good development 🙁
Andy
Andy
So another tangent to wander off on - a "side quest" as the youth might say: converting CD-P4000 to Z5000
Turns out the way the clock is handled is different but it should just be a case of adding a handful of diodes (D419-D423), a resistor (R473) adding some links (w472) and moving the 'B' link wire around the microprocessor (D75212ACW)
see photo's. P4000 is the one with empty sections
There's quite a lot missing from the P4000 servo board and I do wonder if it's just be easier to replace the mech rather than the other way around (how hard is it to adjust focus gain and so on, seems 'not novice')
Otherwise P4000 is missing a 555 timer circuit that's seemingly devoted to turning the display on and off, as well as a regulator and circuitry for motorized volume control, neither of which I need.
Again, for my own benefit this. If I can be clear enough to write it out it helps.
I am becoming very familiar with 90's TEACs. A gloriously useless bit of knowledge to foster 😀
I guess testing it is next
Andy
Andy
Hold on I forgot!!CD-P4000 and CD-Z5000 share service manual and boards BUT DAC board is NOT interchangeable
Did you ever forget? Maybe something important like keys or anniversaries?
It happened to me
I forgot that the grounding is 'not good' on these. I knew this from prior encounters with these TEAC's
must ground audio board to servo board
TEAC used the chassis to do this 🤮 so when you come to it and just drop the audio board in nothing good happens. You gotta do the full install
So, if you have a non functional one - check that the earths
Now I have a working set up, it's time to get elbows out and do circuits and stuff - display and PSU
Andy
If anyone is following
Help needed!
Looking for a connector system with offsets as the attachment - ideally for crimped wires rather than flat.
The only clue I have dug up so far is 5062 but even if that's useful; it's for FFC I suppose.
Turns out, while there is 'plenty' of space for the VFD, it's not below it, so remaking the cables between the display and servo board is a thing. Otherwise its a rather less elegant jumper fest
Any ideas, anyone?
Andy
Help needed!
Any ideas, anyone?
Andy
- Digital Source
- Musical Fidelity FCD, A journey
