NAD 3020e tone controls
Been playing around with a NAD 3020e today.
On my unit, I noticed that the tone controls are not neutral in the center position. There is too much high frequency peaking on the square wave. So if you own one of these, you might want to check yours.
The first image shows the default response with all tone controls in the middle. The second image shows the response after turning down the treble 2.5 dots. Bass seemed to be about right.
In my opinion, when making conjectures, what matters most is experience rather than hypotheses. 🙂
I've seen many older integrated amps do that.
Then if one wants to "repair" something then he would first have to verify if it is broken.
From my modest point of view, I had thought that the pots were the easiest thing to check, if not to "clean". 😉
Edit to add the following link which might be of interest
https://www.diyaudio.com/community/threads/help-w-nad-3020e.286952/
On my unit, I noticed that the tone controls are not neutral in the center position. There is too much high frequency peaking on the square wave......
I believe a tone-controlled amplifier needs to be evaluated with the tone controls bypassed. Some amplifiers like the NAD 320bee have a switch for that. Tone controls may introduce phase-shifts and distortion of square waves.
OK, unless I have made a typing mistake in the simualtion
then the output in regulators' neutral position should be like this:
Looks like a bit bass heavy to me..
I would run RMAA frequency response on that amplifier before making any judgments.
There is a difference from the original board on this board I want to change the resistors on this board! as in the original! Is it possible? Are these resistor values correct? or should I select everything exactly as in the diagram in the book nad 3020 b. blue color is different from original r 515. -180 k (220k) c517 220 uf (47uf) c527 -c529 What kind of potentiometers should I take for this circuit? Input 20k (linear?) for loudness compensation (10k - linear?
He estado jugando con un NAD 3020e hoy.
En mi unidad, noté que los controles de tono no son neutros en la posición central. Hay demasiados picos de alta frecuencia en la onda cuadrada. Entonces, si posee uno de estos, es posible que desee verificar el suyo.
La primera imagen muestra la respuesta predeterminada con todos los controles de tono en el medio. La segunda imagen muestra la respuesta después de bajar los 2,5 puntos agudos. Bass parecía tener razón.
Bien
In my experience repairing old amplifiers, many times the volume and balance potentiometers are very out of value, even in the dual ones, affecting the balance between channels and a very bad tracking, it would not be surprising if the same thing happened with the tone control potentiometers, especially with these types of anti-logarithmic resistive curve "C"
