Yeah that was my first thought as well. Strange room to do speaker evaluations.Not an easy room.
Looks like it from these measurements: https://www.pursuitperfectsystem.com/pear-acoustics-sibelius-speaker-review/Does enough midbass come out of the mouth so baffle step compensation is not needed ?
I might find the time in a couple of weeks to do some measurements.
Well, I just got the news that the cabinets are done and going to pick them up after the July 4th holiday week is over. Toronto is about a 4.5 hour drive each way from my home, but I can’t wait to see them in person.
in the meantime the builder sent a picture of the completed cabinets to hold me over until I can get them home.
After that, they are off to my refinisher in Grand Rapids and hopefully come back home with a beautiful gloss black piano finish. Hopefully, the plans that were published will do them justice to the real ones!,
I am just curious about the opinion of the guys in this forum that are following this project. I guess my first question and using a little imagination, how do you think these cabinets compare to the real ones?
Without seeing them in person and providing the build plans to my speaker cabinet maker, who does this for a living, I noticed two things immediately.
First, the bottom section of both cabinet bases should be doubled according to the plans and the originals. I dont think it will make any appreciable sonic differences, but then you never know?
The second thing that I noticed is that he rounded the corners of the vent / port on the bottom of the cabinets. the originals look flared out to me? Whether on not it makes any appreciable sonic differences is subjective and it may not make any difference?
I may be a little nit-picky or maybe even a little OCD, but I am thinking that a lot of research and trial and error, went into the original design and then fine tuned acoustically be an experienced audio engineer / musician.
So, there is an old saying that the “devil is in the details“ and I want to make sure that I captured what the original designer had in mind, or am I being overly cautious?…
Your thoughts, anyone?…
Hi a700256 I think it will not be a (big) difference about the round corners and the single bottom panel.
Your cabinets looks fine.
How about the internal panel?
I cannot see it on the picture.
Yea I can’t see them either but I had to send him the felt wool from Parts Express so that he could install it based on the plans.
So, hopefully the baffle board is in there with the correct dimensions and angle?
I will not know for sure until I come to get them in a few weeks?
About your “ second thing “: it looks angled or flared out because they use mitre joints every where (sides, front, back, top and bottom). I hope it helps.I am just curious about the opinion of the guys in this forum that are following this project. I guess my first question and using a little imagination, how do you think these cabinets compare to the real ones?
I wonder if a judicious handful or two of stuffing here and/or there might get you to where you want to be.
certainly Scott and Dave represent that their enclosures are designed to within an inch of their lives... but then indicated that moving the driver out 3/4" to accomodate a thicker baffle.
maybe rely on your driver choice first and foremost?
Honestly, I think you are over 60% there, for less than, what, 15% of the cost ?
Pearl's driver is probably better, and the box has been trial and errored in over TIME.
I like that he encourages people to build their own boxes, that say's a lot.
I have a folded Voight pipe with MAOP10.
I used Scott's design and folded it.
Pretty sure that's what a Sibelius is.
I was surprised that I needed a notch filter centered at 8k but it works well.
All of the descriptions of the Sibelius are playing in my living room.
A very musical, real sound.
Not audiophile but music lover
@sterlingmck
it's my understanding that Enabling the driver cone would have dealt with the 8k issue.
did you try that or Dave's simpler approach?
I don't know if I trust myself to monkey with a $110 each Mark Audio 10.3, either the thickness of the mixture for the dots, how many, and where to put them.....
8khz is where the s's and t's land, or too much shhh......
Can become quite irritating if resonance is there................
Sorry Dave
Voigt it is.
I have enabl'd a few drivers in the past.
It's not difficult and very effective.
I may still do that.
A notch filter can be undone dots can't
My approach to enabl is getting it slightly wrong is much better than never doing it at all
Voigt it is.
First time poster...I just spend the day going over this thread (good use of my time while down with the flu in bed). @Hondasnl I plan to build your design, awesome work so far. I need to get hold of a set of 10.3 but it is a special order. I've asked @darcher the distributor in Aus to get me pricing. Was considering the Alpair 11MS but I am a hobbyist woodworker not a sound engineer so I will need a plan to work from......
I recently build my first set of speakers using CHR70 (bought from https://www.darcher.com.au/ ) * thanks @planet10 for the info *. I used the inside design dimensions from https://www.frugal-phile.com/ (Slim Classic GR dCHR-Ken70 1v01 Mark Audio CHR70.3 ) and adjusted for my stock thickness.....I just bought a new Marantz amp and have yet to test them in a good setting. Have played them on my Yamaha AV and they sound good but lack base as expected......will test the new setup this weekend.
Now I look forward to build the Sibelius copy...
@Hondasnl when the hangover wears off lets see the progress…\
- Full Range
- Pearl Acoustic Sibelius
