Got 4FE32, will travel
music soothes the savage beast
Joined 2004
Friends, i need suggestions for small bookshelf enclosures for 4fe32 that i found in storage. I am thinking about making small travel system. I got mp3 player, small classD amp, even found tiny sub. Now i need something covering 150Hz up. Something for hotel room instead of headphones. Portable, cute...
Yes, that would likely be easiest and would work.
But it could be little bright. How about small tl to boost 100-200 Hz range. I think X did something like that, have to search for it.
  • Transmission-line-maze-of-small-3-inch-2-5-inch-speaker-4-inch-bookshelf-speakers-hifi.jpg_640...jpg
I don’t want to spoil your experience, because it’s a fun driver that punch way over its price tag, but I have an issue with the peak/breakup around 8kHz.
It’s easier to see in this measurement than in the data sheet.
https://www.dibirama.it/home-page/largabanda/631-faital-4fe32-16-full-range-4-16-ohm-60-wmax.html
The listening fatigue kicks in after a little while and I simply wants to turn the volume down.
What works for me, is a few thin coats of LTS 50 Coating liquid from Visaton.
On the 4fe35 I settled for 6 applications.
Oh, sorry for the confusion.
I used both 4fe32 and 4fe35 that share the same cone. But to be fair, it’s the 4fe35 16ohm I have tested the Lts-50 on.
The 4fe32 I used felt pads actually. That’s a not destructive test you can easy do.
Can you give more info or a link with info of this mod please?
I run 4FE32 (8 ohm) drivers in Tabaq (ML-TL) enclosures with a BSC. No sub needed. My sub is gathering dust. The Tabaqs are floorstanders, so not really travel speakers. But you can always fit some castor wheels to the boxes.
