Garage clean up
Joined 2024
Dears,
After years of hoarding I am left with no space in my garage to install work bench for router and other messier construction works. So many things for which to use I would need several human lifes, so time to get rid of it.
It would be my great joy to pass bulkier items, but than again I know these are most difficult (and costly) to pack and ship, so please cherry pick what you need. I really hope that this stuff will be up-cycled and continue life.
Nothing what I will list is fake, components and parts are really old.
In second post I will make one "please read first " note.
Please read this first:
  • I will post one group of the items in separate posts at the time, it will take few days to go through the garage 😱
  • All items are vintage electronics and parts, no very new products here.
  • For hygiene of this site I will not put pictures unless I have link to them. When - if someone is interested; I will make and post pictures and details.
  • I will not price items now, there is too many. If someone is interested into something, we will find fair price together
  • No experience in P&P neither, so I need to find out the cost when I know package size and where it goes
  • If you have mercy on me, please don't ask me to do P&P for under 50 € delivery
I would be happy to accept in exchange:
Please read post #2 first.
Vintage semiconductors, I think this is of most interest, so it goes first. After part number in brackets is available qty. All parts are NOS unless it is noted that they are used before
1. Transistors:
  • pls read this for high voltage TV parts: https://www.diyaudio.com/community/...exclude-shipping-handling.413903/post-7709714
  • MJ darlingtons in TO3, these are for Marshall SS guitar amps: MJ2501 (9), MJ3001(5), MJ2500(15), MJ1000(7) , MJ900(5)
  • MJ TO3 . Mj802(16), MJ4502(3) MJ15004(6), MJ15003(1), MJ15015(4), MJ15016(3)
  • TO3 RCA BD311/312 (3 pairs)
  • TIP3055 (9)
  • MJE3055 (8)
  • 2SK1058/SJ162, sorry only 1 pair 🙂
  • Various old TO3 and TO3P mosfets, some used, not too many pairs, like IR425, BUS98A (4 pcs), IRFPC50 (few pcs),
  • 2n3055(4) 2n2955(3)
  • BUZ42 (many), IRF820(6)
  • A box full of new Germanium transistors, different packages, please ask
  • MJE15030/31 (15 pairs) but I want to keep 8 pairs...
  • PHN210, dual SMT N mosfet, 10pcs
SSM220P, ultra low noise dual PNP(")
Fast rectifiers:
- MBR3045, BY359, BYW19, Ba13363, FEPI6JT, BY359, sd241P, GI824 AND PROBABLY MORE, PLEASE ASK
Led,
- bag of hundreds, pls ask
Chips:
  • LM3886 National Semi; 2 new metal, 2 new TF (plastic housing) + 12 pcs built in 2 BPA300 amps
  • NE5532 (Old Signetics, used) NE5534 (new TI)
  • L272C, dual power opamp SMT
  • MAX 6250, low noise precision +5V reference (for dac or PS)
  • MCP3201 12 bit fast DAC
  • Reused OP27, SSM2141, 2142, 2143, SSM2019
  • Reclaimed audio and other chips from early 2000's pro gear, AK and other DACS and ADC, opams and so on... pls ask
I probably forgot many :-(
Vintage HIFI, any of those I can completely rebuild to as new stage, at cost naturally:
Very nice FM tuners:
  • Sony ST5000F, tank from 1968, at some stage it was recapped and new PS cord added
  • Yamaha CT-1010, untouched, only small damage on top of wooden cover when vase fell on it during Zagreb earthquake :-(
  • QED T231, very interesting and strange tuner, but fantastic sound
Technics RS-TR373 dual cassette deck
Multi channel amps:
  • Sony STR-DG700
  • Rotel RX1050
Both above w/o remote
- Custom pro amp 6 channel, upgraded or original version, pls see here: https://www.diyaudio.com/community/threads/beetlejuice-speakers.409269/post-7635793
I need to keep at least one of those units for my purposes.
Forgot to mention here, I also accept decent and robust MM cartridge (or 2) to play old LP's without being sorry to destroy my main expensive one
PS components:
SMPS:
  • Abletec PA10057/ATNW 1011, in 100-240VRMS, out 5V-6A, -5V-1A +-15V -1A These are studio quality PS with integrated power socket and power switch. Also available is modular rack (19" 2H) that accepts up to 12 of those units, or different cards.
  • MW 320-24, 24V-13 AMP monsters, Be aware they are fan cooled so or remote positioning or tweaking to passive cooling is needed. These are pro grade SMPS that come in pack of 3 mounted in high quality 2H 19" racks. Using only 2 SMPS per rack allows space for additional filtering and +-24v- 13 Amp PS.
  • Fabrimex SRN 5015 -s, PCB mounted Input 11 to 33 VDC, output 5V 3A
  • PCB mounted DC-DC converter input 20 - 60 VDC, output +-15VDC, https://datasheetspdf.com/datasheet-pdf/612619/LPS48D15.html
Mains transformers:
  • a lot of toroids for audio from 30 to 1,600VA, pls ask
  • Few EI transformers with dual outputs for audio
Chokes:
  • dual toroid (not common mode but 2 separate units) chokes sealed in alu can and cemented. These are for pro gear and I have quantity, high power rating but I did not measure inductance yet, pls ask. Each unit with 2 chokes is 400g heavy. This is good for LC filters in linear PS, as well as mains filter.
  • Various common mode toroid chokes for mains filtering
Mains filters: few reused complete L-C mains filters, up to 24 Amp - 275 VRMS capability
