Class A Guitar amp using MOSFET (or power JFET)
Using secondary winding of a tube 12 watt Class A single ended transformer as load across speaker. Great harmonics.
The inductance needs to be high -- 20 mili henry would be about right for 60Hhz low frequency range. 8/(2pi*L)
The inductive load makes it more efficient as it "kicks" above the rail more like a current source. It makes amp behave almost exactly like a tube class A.
I really think the transformer (or inductor) is responsible for most of what make a tube class A sound so good - not the tubes so much.
Power jfet will not be as efficient as the pinch off can be 12V or higher -- a low voltage threshold MOSFET is best. 6 watts output is adequate which means MOSFET no signal dissipation will be around 15 watts. Nedd good heatsinking
That theory is extensible -
  • Autoformer volume controls that sound better than a resistor ladder
  • Transformer coupled DAC output that some seem to like for some reason
  • Lore has it sometimes recording engineers put signal through all-transformer coupled compressors without using compression, to improve the sound.
  • Neve console mic amp plug ins with transformer coupling going in and out
  • All transformer coupled amplifiers / preamps from Japan
  • Manufacturers offering "magic box" type products containing 1:1 line level transformers, that customers attest to "stripping away the digital haze" or whatever.
  • The signal out of every Shure SM57/58; caveat (of course) the older ones sound better having the not cost reduced...
-McIntosh autoformer outputs perhaps going a bit beyond merely providing a better degree of output short circuit immunity.
Wife calls, cant think about it anymore.
