Hi i have a question about dissipation of complementary bjts I have attached a circuit to explain my doubt
The npn Q3 on one side and the pnp Q4 on the other voltage side have very different dissipations Is it normal ?
I know it is a silly question but i was hoping that the symmetry would be maintained also in the dissipations
Is this normal ?
Thanks a lot
By the way if you have advices on the circuit i would very grateful
Is this normal ?
Thanks a lot
You could have a problem with connected the gates of the JFET's. You have no DC path there. The leakage currents must go somewhere.
Hi and thanks for the kind and valuable reply You mean a resistor to ground is missing ?
Moreover is it normal to have such difference in power dissipation between the two sides ? very different
Hi thanks a lot To be honest the original schematic is different ... i am trying to prune it to something more basicAgree, those gates are open, no reference to ground.
Output will float anywhere
No symmetry possible except by chance.
I am fixated on unity gain devices mostly
Hi thanks a lot indeed ! i see in the 2nd case the currents are mirroring each other so much better indeed !
These fets are strange to me But i see that everyone love fets ...
I understand also that when the parts are matched the differences will be lower I read something about npn and pnp being intrinsecally different
From a structure point of view And this will reflect also on some parameters i guess
Any idea about how to lower the HD ? i have pruned the original schematic because i do not need gain
- Design & Build
- Electronic Design
- About dissipation of complementary bjts
