HAMMOND 125ESE Transformer WIRING
I am updating an older Fender Champ amp. For the Hammond 125ese output transformer, it's obvious that on the secondary the black wire is ground and the other wires select the primary impedance as seen by the power tube. I plan on using negative feedback from the speaker to the cathode on one of the 12AX7's. The 125ESE primary wires are blue and brown. The question is which wire goes to B+ and which wire goes to the ouput tube plate for proper wiring?
