Totally accurate!Sure a heavily damped toroid will hum less loud and a slopy wound one will be noisier. Anyway, if you have a DC component, any toroid will get loud.
We had this problem decades ago. Even vacuum epoxy impregnating the coil, a shielding layer, dunking the whole thing into a cup of resin and outside metal shileding didn't help. All these things you do to call it an adiophile transformer simply failed.
Lock it away or use a DC filter, these are the only options in a DC problematic region.
PS a mains filter is no DC filter!
DC filter use diodes and very large, low voltage capacitors. A concept many don't understand. 10 Volt capacitor at 230V AC mains...
If you are designing toroids at 1.2 T, then you are not getting many of the advantages that toroids can achieve. You may as well use a laminated core, not a toroid, as a laminated needs to run at about 1.2T. Toroids can run at much higher flux densities, which is the key to some performance improvements.When doing specification for shop, ask for B 1,2T. Then they need to calculate core dimmensions for given power. Usualy they need to go with bigger core, so they have enough space for additional wire needed for lower B. On the end probably 50% more expensive.
What do you mean by 'more high frequency noise to be passed'?
I reckon he's referring to the bandwidth of the transformer. 'More HF noise passed' implies wider bandwidth. Toroids have lowest leakage inductance (and highest inter-winding capacitance) which means they're highest bandwidth.
Happy to be enlightened if I've gotten this wrong.
I presume you mean this. The OP (and whoever else) should be sure to read the whole thing:There is a comprehensive article from Rod Elliott ESP 06 MARCH 2008, Blocking mains DC offset from xformers
https://sound-au.com/articles/xfmr-dc.htm
This is sort of a loaded question. In a perfect world, 100% of the primary lines of flux cut through the secondary winding, and are delivered to the load. But in reality, a % of the flux is not coupled to the secondary winding, and escapes into the air. I refer to this as 'stray magnetics', (not leakage inductance, which has other parasitic components). In sensitive applications, such as a preamp, stray fields can cut across the low level input circuitry and induce noise into the system - which would later be amplified.
I'm not familiar with the term 'bandwidth' being associated with a 50 or 60 Hz power transformer. From my experience, bandwidth is a term used for audio input or output transformers that require to pass a wide frequency response. Among other attributes, they have a special interleaved construction that allow them to have a wide bandwidth.
A toroidal core is a nearly perfect magnetic element. Seriously! Clever design coupled with skilled machine operators can produce 'precision wound' toroids, have the lowest possible magnetic emissions. Although there is much confusion on this topic, the reduction of stray magnetics starts with 3 elements - core material, core geometry, and winding precision.
A skilled magnetics engineer should know how to achieve this. Hope this helps.
Figure 8 in the article is a good solution.There is a comprehensive article from Rod Elliott ESP 06 MARCH 2008, Blocking mains DC offset from xformers
Toroids have much lower winding resistances that laminated transformers, which is key to their high efficiencyShould I expect a toroidal transformer to always have higher winding resistance than an equivalent VA EI core transformer?
Hello people,
Thanks for reaction!
I was ordering my trafos with 20% oversized core, vacuum varnished several times (once for core, for primary and then for secondary).. This reduces buzz to minimum, but it's still there. Nevertheless it's much better than all commercial audio trafos I have bought.
This is OCD issue, with slightest music it's not hear able, but hate the buzz....
I tried DC blocker at mains input, no difference where I live.
I also sealed many trafos in epoxy,and this is very liquid epoxy with 24 hrs settling time, this penetrates deep, first I removed outside wrapping. This also helps, but still it's not zero buzz. Here are examples
Then we have commercial Amp Trafos, mostly EI core welded on corners, and the buzz is even lover than with crazy effort I put in toroids, what's the catch?
I could write a novel based on this post. In short, you are attempting to muffle the noise, rather than solve the problem at the source.
Hi Brian
Thanks for your offer. I'm interested in your view on potential issues that might arise when using a toroidal power transformer with a split primary winding (120-0-120v) as a pushpull output transformer using, in my case, an 8v secondary to give around 7k2 ohms pp with an 8ohm sec load. Possibly a similar query to post #3.
Are you referring to an audio output transformer? Not a power transformer. Where are you deriving a 240 V center tapped input?
If I understand correctly, he intends to use a power transformer as a push-pull output transformer for audio.
There have been questions around how to make toroidals handle standing DC currents, as in single ended output transformers or in power supply chokes. EI or C-core get a gap, how does that work for toroidals? A cut in the core?
Due to their extreme high efficiency, and square hysteresis loop, toroids move abruptly into saturation, and have low tolerance to DC on the mains. In a toroidal core, all of the magnetic grains are aligned in the preferred direction, and there is not a gap. It is possible to gap a toroidal core, but it is a slow labour intensive process, and then a toroid would operate similar to a laminated core - thus not much point to gap a toroid.
Other types of cores, such as EI, L7, R, C-cores have what is referred to as a round hysteresis loop, meaning they move closer to saturation slowly, and dont saturate easily. In these configurations, airgaps are inherent to the core construction, so they are much less efficient than a toroid, and up to 40% of the grains are aligned in the wrong direction. This increased the core losses, and substantially lowers the efficiency, can run much hotter (which shortens the life of other components in close proximity), but a positive side affect is an ability to be less sensitive to adverse line conditions.
Its a trade.
Its a trade.
So are we to interpret this as saying that talking about the 'bandwidth' of a mains transformer is inappropriate? The reason its of interest in the world of audio (quite apart from using a mains transformer as an OPT) is there's a fair amount of ultrasonic noise on the mains and it would be nice to have a transformer which doesn't couple this hash very well into our audio kit.
Hi Brian,
Great that you joined, Im also fresh here, just a month old member. Thanks for your offer!
There is one thing about toroids thats utterly annoying, a buzz, horrible noise worse than any other. Here people design - 120db noise circuits for power amps, what's worth when toroids just buzzes.
The shop where I was buying my transformers was over sizing the core for about 20% of nominal power, then vacuum lacquer it and then double bake it. Result is much better but sometimes it still does very quiet, but horrible buzzz.
Can we get rid of it all together? Make completely silent trafo in 300 to 1000w range, is that feasible?
The same question, buzzing toroids, has been asked in this forum many times - all in different words. If you search publications, there seems to be contradictions and can be not totally accurate.
Core size is irrelevant to emitted noise, and its possible cores with a larger mass have the capability to be louder! In theory and books, a lacquered core is supposed to attenuate noise. In reality,
I have never found that to be an effective solution, and in fact vacuum varnishing degrades the properties of the core. The last stage in producing a toroidal core is annealing, where they run it through a furnace for 12 - 16 hours to remove stresses in the magnetic steel. Then if the core is varnished, that will re introduce some of the stresses removed in annealing.
If the noise changes daily, thats a reflection on the condition of the ever changing mains.
The best solution I believe is a simple DC blocking circuit. I know for a fact that many high end audio and video companies incorporate this in their products, so it has been extensively proven in the field and is invisible to the quality of the product. Then you have ALL of the advantages of a toroid - which are significant - with zero noise.
Hope this helps
Hope this helps
- Power Supplies
- Toroidal Power Transformers Questions
