Is there in Bass, no Stereo?
I played a bit with Light My fire,
Here is my take on Light My Fire. It's a very stereophonic mix. You can see that it's consistently about 5.5dB more side than mid, all the way across.
Reactions: Netlist
Nice. That seems to prove that both mono and stereo bas exist.
Although I think many mixes are done with mono (center) kick drum.
I'll try that plugin in Audition, for I'm not familiar with Audacity nor mid/side decoding.
Where can I find it?
Just to annoy you all, here are a few more. 😛 I'll let you decipher them and decide how stereophonic they are above and below 100Hz
Remember, the MID channel is the mono component of the track, the SIDE channel is the difference between the tracks (stereo)
Reactions: AllenB
Thanks, I have a few Voxengo plugins. This one will also most likely work in Audition.
It would be nice to compare vinyl and CD masters to see the difference.
Unfortunately, we both don't have enough material, so we need a volunteer.
Reactions: Pano
This made me recall that there have been various "pan laws" or "pan rules" employed, the changes the signal level when panned between the center and left or right to achieve a steady level when panning across the stereo field.
With many DAWs (Digital Audio Workstations), an engineer can now choose the pan law, but that wasn't the case in the pre-digital era.
In analog mixing consoles, -3dB, was generally most common pan law, SSL used -4.5dB, the Amek 3000 used -6dB.
Depending on the console, monitors used, mix and mastering engineers, there is a huge variety in the L/R composition and frequency content of stereo recordings.
Whether you like it or not, you won't hear it the way it was recorded if you play back with subs summed mono, or a single sub if the main speakers are high passed.
Reactions: Pano
Here is something fun. Sergio Mendes Agua de Beber from CD and from vinyl. First we see the mono (Mid) signal showing Vinyl vs CD. They have a similar FR, the CD has a bit more bass and top end.
Here is the stereo difference signal (Side). Again, very similar FR between the two and we certainly see that <100Hz is not mono on the vinyl nor on the CD.
Here the spectral pan of 'Us and Them' (Pink Floyd) with everything that normaly goes to the subwoofer. (High cut 120Hz)
Very stereo bass. If it were strickly mono one would see a horizontal line in the middle of the spectrum window.
  • Thank You
Reactions: Pano
