Anyone had success running Basta on apple silicone in a Parallels / Windows 11 session? I cannot get it to run.
I just gave it a shot for kicks and am getting an error ('NAN' is not a valid floating point value) when trying to run the executable. Is this what you're getting as well?
I thought compatibility mode would have been your issue, but it's not working for me under any mode, nor with tweaking x86 emulation settings. It works for me on old Win7 & 10 PCs, but I don't have a Win11 PC to test though.
I usually run into problems with hardware because of the drivers whereas software typically runs fine (at least what little I've tried) in Mac silicone + Parallels + Win11. I'm not certain what's going on here.
Dang! That was a good thought. Tried it but no go. I think it won't work at all with M series macs 🙁n Win 11 it was not possible to run Basta until I used this workaround.
In your file manager Right click on Basta.exe > click Property > select the Compatibility tab, then select Win 7 and check the control box Run as administrator.
- Basta under Windows 11 / Parallels, Apple Silicone
