@JMFahey
The only reason I can come up with, is structural integrity.
Doing the way they did it, makes it a lot stronger.
The mounting plate of the Conrad (Ela) transformer is welded directly on to it.
While most other transformers have a sperate mounting piece that's folded around it (see photo above).
I will have a look how those are made as well.
Or just a legacy way of doing things to avoid infringing some kind of patent.
Probably the patent is long gone but their machines just work this way.
Just curious, does that assure a no-gap connection between E and I?with a quick clamp and run an electric welding bead across the joint on each side.
No, but it does ensure an additional eddy current load from all the tiny short circuits they create. Welding the lams is a cheap, quick and dirty shortcut usually reserved for mass produced low margin parts like microwave oven transformers.
Maybe there is One BIG Factory In The Sky making all of them or this type of cheap construction became an unwritten "standard" ($$$$$).
Neither option would surprise me 😉
There is a video about EÜPA, "the largest factory in the World" which apparently makes all the coffee makers, pressing irons and electric grills under all kinds of brands do after that, nothing surprises me.
Worst thing?
Video Is about 10 years old.
In the meantime China became "too expensive" 😲 so it was uprooted 😱 and moved to Vietnam.
So that style of manufacturing contributes to "global warming" by loading the AC mains additionally, every time I run my microwave. I wonder if that's in all the transformer based wall-warts as well? Thinking stuff plugged 24 / 7 -No, but it does ensure an additional eddy current load from all the tiny short circuits they create. Welding the lams is a cheap, quick and dirty shortcut usually reserved for mass produced low margin parts like microwave oven transformers.
DPC-16-1500
Dual 115V primaries, dual 8V secondaries, 24 VA 50 to 500 Hz
$10 and quantity discounts available, shipping gets much cheaper with quantity
No welding here
https://www.ebay.com/itm/225572227572?itmmeta=01HWM2RGKB42J4AY16TR9NPRPT&hash=item34852709f4:g:4yYAAOSwNzNkW-O0&itmprp=enc:AQAJAAAA8Lf9yD16pGkIJgj1384mCtV9qqtBtOpvWQLJEhJqoU4F0W2jbFtEbPcmYZHP3XUXku8PJu6fnuw5vVDOmWEeeRnE45cqutjbcaZOowE41zrdyENJATZq1hkPXwl34LcKiwHHL7QUwtR0L6yxlTYzG6lnhZ7YVOTfFXdLcpKdAblzut34UWJyjJFskFLZ2+0zLZFS/eBHL7ON7WHk6V2cEx/fyr/PRdALxbgr7ZZtysbgbEuuWOvm42z6gEuJLRwk91l5/YBT0wzaSIyQerBYE56B0Nhp3MUS+Ix9WeJqhLZqnCCsc3S/3WkdR+7+D+DJ7w==|tkp:Bk9SR96J4oLlYw&shqty=10&isGTR=1#shId
However, the EWC parts have higher inter winding capacitance than the original Signal Xfmr DPC parts.
Signal Xfmr version:
No welding here
The EWC part has 302 pF from primary to primary. 276 pF from primary to secondary (worst case ), 280 pF from sec. to sec.
The Signal part has 181 pF from primary to primary. 248 pF from primary to secondary (worst case ), 252 pF from sec. to sec.
The Signal parts I've seen are typically more like $20 each. I see one Signal dual 8V DPC-16-1500 from the UK for GBP 40
I would suggest using the Crowhurst Twin topology with any of these, to double the primary voltage without increasing effective primary capacitance.
(ie., minimize voltage difference between the primary halves)
Any number of them could be series connected (primaries) in Circlotron mode.
Don't bother trying to dis-assemble these for SE, thoroughly epoxied together.
I doubt that the Eddy Current losses amount to much of an efficiency loss at 50 / 60 Hz, but they will act differently and possibly unpredictably so across the audio frequency range. Unless every weld is exactly the same as every other weld there could be some part to part variation in HF response.So that style of manufacturing contributes to "global warming" by loading the AC mains additionally, every time I run my microwave. I wonder if that's in all the transformer based wall-warts as well? Thinking stuff plugged 24 / 7 -
@smoking-amp
These uselessly long links can often be shortened!
e.g. https://www.ebay.com/itm/225572227572
Piemme Elektra
https://shop.piemme-elektra.it/Categories/92
With a resource like Piemme Elektra, why would anyone bother with speaker distribution xfmrs? I am amazed that Piemme Elektra is not better known.
I agree. I'm currently listening to a pair of monoblocks with good sounding (and very nice looking) SE output transformers that costs around 60E each from Piemme Electra.ith a resource like Piemme Elektra, why would anyone bother with speaker distribution xfmrs? I am amazed that Piemme Elektra is not better known.
I'm keen to purchase a pair of transformers for Piemme but they've emailed to say they won't ship outside the EU and I'm in New Zealand. Sigh...
Because distribution transformers are cheaper, even more so when I include the shipping.With a resource like Piemme Elektra, why would anyone bother with speaker distribution xfmrs? I am amazed that Piemme Elektra is not better known.
Probably a little smaller as well.
Stock also seems fairly limited?
Is this made to order or NOS?
- Tubes / Valves
- Audio transformer for small tube projects?
