I purchased a ~1970s vintage 8500 II Pioneer Amplifier from Japan. I am wondering if anyone here does restoration on older equipment and has recommendations on replacing the transformers vs using it on a step-down transformer. The Japanese unit is designed for 100 vac at 150 watts. I assume I can run the unit on my Variac and see what I think.
It looks like (from the service manual) I could replace the existing transformers with 120 to 35-volt transformers (I'll verify the voltage when I have a unit). Using Anetk toroids would be pretty cost-effective if they fit. I don't know if there is an advantage of one option over the other. In any case, I would keep the existing transformers in case I want to put it back to stock.
Any advice would be appreciated. I do plan to re-cap the electrolytic and fix whatever else I find. I'll probably preemptively replace a few transistors that are known to fail as well.
Original transformers from US based sellers are available on eBay - I would place those and have a unit as near as possible to its original state.
Should I decide to go for replacements (toroidals etc) I would consider placing them in an external box - less noise inside the amplifier.
I do like the idea of keeping it as original as possible. Is there any reason to believe the original transformers would be quieter? I always thought toroids were better in this regard.
You might find this old thread interesting, about converting a 100V Japanese to 120V, using a relatively small conversion transformer.
https://www.diyaudio.com/community/...tage-change-100v-to-120v.393989/#post-7224651
How does this piece of knowledge relate to this particular thread?I rebuilt my sx780
He mentioned rebuild and these older Pioneers make outstanding platforms for very high end new amplifiers and turntable RIAA Eq.
Oh, really?these older Pioneers make outstanding platforms for very high end new amplifiers
- Pioneer 8500 II rebuild
