6AS7G SE or P-P?
if you can accurately balance the currents on each side.
The cathode biasing will do that for you automatically.
Fixed bias on such low mu toobz is a sure path to disaster.
I eventually used resisters on heat sink tabs to the Aluminum chassis. They need to be 10 watt rating.
And more recently added a couple of pieces of scrap Aluminum extrusion externally to better dissipate the heat.
In my case building this amplifier was a 'Proof of Concept'
experiment to overcome the large drive requirements of low mu toobz.
I never built a complete amplifier, the concept worked, I moved on the other problems. 👍
