I'm guessing Eric doesn't have the money to take someone to court anyway. It's all bluff that he can't back up. He'd have a better chance of wining if he took the money to Vegas.You better have $50-100K to begin
jeff
That will be an equally hard act for a company the size of T. How big is T. anyway turnoverwise?$100 million in legal fees
And to harp a little further where are professional critical reviews of Bose speakers? I heard that once a rookie reviewer tried it and he was lucky to save his shirt. Why nobody says D'Appolito is an old fool and his famous configuration of running midwoofers in parallel up to 3khz is a scheisse? You move your head and the tonal balance shifts dramatically. Possibly because he is not a fool and he made an educated choice.
Or know how the system worksYou better have $50-100K to begin
Quite why HiFi makers would suddenly think litigation against individuals is a good idea - is unclear. Lawyers grant jurisdiction to the court/tribunal and will simply hoover up most of the benefits.
Surely it's cheaper and better to work with reviewers to improve the products.
As for little holes causing resonances, I think it's more likely that they would simply causes damping, and that the observed 250Hz bump is a measurement error or a real feature of the item tested.
The constructive response would have been to ask for a new measurement with the feet in. Instead, there were threats - so perhaps the maker doesn't think the feet holes cause the bump either... so there's that.
If the maker drags it to court, and the reviewer decided to argue in the legal jurisdiction for whatever reason, the maker may need to demonstrate that the holes were the problem, which would be interesting.
So now I'm curious to see the 'with' and 'without' feet frequency plots
Perhaps D'Appolito just got on with the engineering, and didn't pick fights? This is just my educated guess, but it seems likely.Why nobody says D'Appolito is an old fool
The Streisand Effect often gets ignored, but is quite real. Tekton appears to gain only negative publicity from threatening reviewers.
There was the same with some guitar tutor system recently too, instead of the usual boring reviews, that too turned into a circus
In general with this type of legal case, the lawyers win.
Another benefit of DIY is to avoid all this horror
Because nobody is asking for reviews maybe. Has Bose even made speakers in the last 20 years?And to harp a little further where are professional critical reviews of Bose speakers?
jeff
Erin shows the updated plots in his recent video. There's a tiny difference in the bass response, but that's about it.So now I'm curious to see the 'with' and 'without' feet frequency plots
jeff
I found the original science review:updated
https://www.audiosciencereview.com/forum/index.php?threads/tekton-m-lore-speaker-review.48732/
Quite an interesting read!
- General Interest
- Everything Else
- Interesting Post from Audio Karma
