Ebay seems to have plenty of what you are looking for at far more reasonable prices. Try search term "turret terminal" what pops up is a selection of both insulated and non-insulated types.
Fair Radio Sales is going out of business in June 2024 (owner retiring), they have a huge selection of ceramic standoffs, feed-throughs and insulators:
https://fairradio.com/?s=ceramic+insulator
I have used theese , unsure about how many volts they can handle, but probably beyond 1kv. And they are cheap.
as_audio said:
https://www.ebay.com/itm/1963321108...id4/36egu1caenuq1lA2m94g==|tkp:Bk9SR5iirr7YYw
For some reason, you changed an S to a 5....... Obviously, you won´t get the same result 🤣 🤣I was curious so I tried your link again. This is what I got.
Don't worry, I don't think it is your fault, no idea what's going on.
Jan
Can this happen with copy and paste ?
The link in post 16 works.
Your copied link leads to nowhere.
That´s what I meant. Your link works, Jan´s did not.Your copied link leads to nowhere.
Difference is, that your link has a "S", where Jan´s copy of the same link has a "5".
And NO..... this can NOT happen by copy/paste. Fault has to be somewhere between elbow and finger tips 😉
🤣 🤣 🤣 😍This must be due to the fact that Jan is a 5S ( five stars) editor .
It is more subtle. The link in the msg is shorted by the forum. You see some ellipses ... in the link, but thats just the displayed part, the underlying URL is still there. BUT when you quote it, you quote the displayed txt not the underlying URL and get an error.
When I use Andreas' original link I get the right page, when I click the quoted link, not.
The shortening of the link with the ... may also depend on the width of your display window, I haven't checked that.
Maybe we should tell Jason about this.
Jan
Jan
A more sad fact is that old links to old forum entries end at the wrong place after forum relaunch.
