Bipole phone speaker?
I've never really torn down a modern phone but wonder if it would be possible to get better LF response out of a common phone by driving the screen and back with a bipolar voice coil. If it could be better enough to warrant the difficulty in rearranging everything..
There is no empty space inside the modern phone. Packed with electronics and batteries.
The best way to do this is... a blue tooth speaker.... or an external DAC with built in battery, an USB-OTG cable and earbuds.
There is NO room inside a modern smart phone. None.
If you could 3D a deeper back shell, then you might be able to mount something there to give you a bit more.... "bass"...
I’ll use a wire.
dave
Reactions: Horneydude
Sure, but I'll put a 24/96 ( minimum ) DAC somewhere in there. The Audio coming out of the phone is not so good.
Oh, I got a pair of Markaudio Tozzi Ones. In red... smaller than those you show. Without the dots.
It's never going to be hifi, and the lack of internal volume would be consequential, and if it helped at all it'd probably take too much power. But I think the magnet assembly could be used to help divide the moving mass equally front and plastic back, so only one coil needed. Also the entire screen assembly would have to be bonded solid for it to work, which I don't think is how it is usually done. Too many problems and just a curiosity.
It's never going to be hifi, and the lack of internal volume would be consequential, and if it helped at all it'd probably take too much power. But I think the magnet assembly could be used to help divide the moving mass equally front. so only one coil needed. Also the entire screen assembly would have to be bonded solid for it to work fix my speaker, which I don't think is how it is usually done. Too many problems and just a curiosity.
First off, my HT setup. Denon X1400 85 WPC, B&W 305 Front stage, Infinity surrounds. Sub is Infinity 10". The surrounds are shot. Adding a SVS-1000 sub. Need some advice for bipole surrounds.. Thanks in Advance,
