I need your help
您好,在我的 Raspberry Pi 上安装 PICOREPLAYER 并连接 TRAMSPORTPI 扩展板后,我在让 SQUEEZELITE 正常运行时遇到了一些问题。具体来说,当我尝试在 SQUEEZELITE 设置中将输出设备设置为 HIFIBerry DIGI+ Pro 时,它无法启动。我已经仔细检查了所有连接,甚至重新启动了连接,但问题仍然存在。是否有其他人遇到过类似的问题,或者对如何解决此问题有任何建议?任何帮助或建议将不胜感激。提前致谢!
Hi, after installing the PICOREPLAYER on my Raspberry Pi and connecting the TRAMSPORTPI expansion board, I'm having some issues getting the SQUEEZELITE to run properly. Specifically, when I try to set the output device in SQUEEZELITE to a HIFIBerry DIGI+ Pro, it won't start. I've double checked all connections and even restarted them but the problem persists. Has anyone else encountered a similar problem or have any suggestions on how to resolve this issue? Any help or advice would be greatly appreciated. Thanks in advance!
李先生
你好,这是一个英文论坛。您必须用英文在这里发帖。如果您想得到任何回复,请在发布前使用翻译软件翻译成英文。
Mr. liluosheng
Hello, this is an English forum, you must post here in English. If you would like any responses, please use translation software to translate into English before posting.
