Digitally controlled analog shelving filter (low/high shelf eq)
I'm offering some suggestions purely on instinct.
I'm thankful for any ideas right now, so keep them coming! 👍
I would try making Rf=0
That makes sense! Some schematics on the internet leave out Rf and Rin. Unfortunately, bridging them didn't make any difference.
unity gain stage
Yes, it's oscillating.
P.S. Make sure you're using x10 scope probes.
I've never used anything different. Also, I tried probing before and after some additional buffers, so technically the probes shouldn't have any effect.
Reactions: rockies914
Could the phase shift caused by the treble capacitor be the culprit? After all it's in the feedback network and might turn the negative feedback into positive feedback that doesn't get attenuated enough depending on the pots position. Are high quality caps important for this circuit? 🤔
Well, turns out the caps I've been using aren't that bad. At least that's what the impedance analyzer tells me. (Being an electrical engineering student at a well equipped university has it's benefits.) 😅
Progress! Getting rid of the oscillation requires a combination of measures:
  1. Clean and stable power rails.
  2. An opamp that isn't too sensitive to noisy supplies (high PSRR).
  3. Adding a capacitor from the opamp's output to its inverting input does help but it essentially creates a low pass filter.
I guess, on a proper PCB measure 3 could be omitted or at least the capacitance could be decreased to a point where it doesn't affect the audio range.
Power filtering is always important but can be challenging on a breadboard.
Using a "better" opamp certainly won't hurt and a NE5534 is by no means high tech, nor particularly expensive.
For now I'll leave it at this point. Maybe I'll add a test with the digipot at some point, but that shouldn't make a big difference.
tl;dr -> The Baxandall circuit may be "tried and tested", but implementing it isn't as trivial as it might seem at first glance.
From post 22, you connect the opamp as unity gain stage and it oscillates?!!
I presume you tacked a short from opamp output to minus input? Assuming the passives were left in place and R6=0, I believe this connects the output with R2, R3, R5, and CT. These parts and their associated passives certainly present an odd load network, but the impedance is modest and the opaamp should have no problem driving it in a stable manner
I suggest determining what components are provoking the oscillation. I note the oscillation is about 500kHz in photo above. I suspect wiring strays to the pot might involved. Does oscillation frequecy vary with pot position?
Would you post pictures of your setup and breadboard?
Reactions: Error!
To bring this topic to an end: There must have been a problem with my breadboard setup that caused the opamp to oscillate.
Also, the usually quoted version of the Baxandall EQ seems to be prone to causing issues with (especially JFET type) opamps.
(There's a nicely written section about this in "Small Signal Audio Design" by Douglas Self.)
With appropriately sized components the implementation of a digital potentiometer works perfectly fine.
Sorry for the very late response.
Thanks to everyone who contributed ideas!
