Onkyo M-505 update
Hi again. I was finally able to replace all of the electrolytics in this piece of crap only to discover that it still produces exactly the same bad cap smell.
I suffered a near fatal heart attack a few weeks ago, and had a friend help me finish it yesterday.
I don't know what else could be producing the smell. The amp shows no sign of corrosion, yet it smells like burning rust.
It also runs cool all the time, so no problems with overheating.
I am at my wits end here.
Well, the smell comes and goes like something leaking, and the whole amp runs cool.
I haven't detected any problems with the transformers.
I do suspect a possible issue with the rectifiers which could be causing the mains capacitors to leak and bulge.
If all electrolytic caps were replaced, by elimination, they cannot possibly be the cause.
Blown electros smell fishy, literally.
I know the smell of burnt transfos, but that's like lacquer wire. Burning rust is not a description that triggers my smell memory database 😉
Could it by any chance be the PCBs get hot in places and start to smell? They look to be made of phenolic paper.
Unless they are receiving too much voltage. I know first hand what a bad cap smells like. I guess you can say that it smells fishy.
The amp doesn't run warm at all as far as I can tell.
Yes, negative (black) lead on the middle point between the caps.
Red lead on the upper cap should give you a positive voltage and a negative voltage on the other cap.
There is a copper bus connecting the 2 caps plus to minus. Then the other terminals are connected to the plus and minus feeds of the amp boards, which contain the rectifiers.
What setting should the meter be set at? Should I connect the leads to the feed terminals?
