How much current do you need at the output?Hello. I really like to build this,
1.please help with the component value. I cannot understand the resistor and capacitor value.
2. How to set the output voltage to 12 volt?
Please help me. Thank you so much. Doni
Thank you. 12volt/2 amp.
1. What component value to be changed for 12volt/2amp?
2. I don't understand the resistor value on that simulation. For example R15 470m. Is that means 470 mega ohm?? R9 1m. 1mega ohm? Is that correct?
Thank you again...
Thank you again...
Thank you again...
