Greetings, first post here and mostly noob in analog electronics, so please be gentle..
So I found in an thrift store Philips N6330 (sibling of AKG K240), which are 600 Ohm headphones and need something to drive them and there's not as many options as I expected. Not ready to invest more than pocket change yet so found this TPA6120 board on aliexpress for ~7EUR which looks like it should do the trick for now, but I don't have a suitable +- 12V transformer readily available. I suspect this board has something like pair of LM7809s on it as it wants +-12V AC, but don't have any means to verify it.
So the question is, if I bypass rectifiers and connect two 9V batteries, would that be enough to drive 600 Ohm headphones, at least to see if I like their sound and buy something better?
The other option is get +12V and -12V DC from old ATX power supply, would that be a better choice?
Here is a helpful (edited) description:
"TPA6120A is HIFI stereo headphone amplifier. It can provide 800mW power to 600Ω with a ±12V voltage. The operating voltage range is ±5~±15V."
According to the description, the board can run off +/-9 V, but I suspect batteries would not last very long.
Ah, thanks, that's the calculation I needed to see. Thanks a lot!Only you can decide if >110dB at your ears is enough.
Even if it is passed through LM7809 or whatever is there on that board?Hook the 9V batteries up and listen. Quickly.
The ATX supply would be noisy.
- Headphone Systems
- TPA6102 and 600 Ohm headphones, is 2x9V batteries enough?
