Anyone with experience regarding the AV receiver.
Totally dead, except from some clicks in a relay when it's plugged in to the wall socket.
No led status...
Need service manual
Cheers
No led status...
Need service manual
Cheers
Seems to be 2019 model?Need service manual
I would bet you wait about half a dozen of years to get it 😉
There is a RZ820 service manual on HiFi engine website. Rz820 may similiar with RZ840 on the control section.
Couple weeks ago, I fix a Sony AV receiver which was total dead no display and can't turn on/off. After checking the power supply of system IC, I found the voltage is worng then I found a crack on the trace and fix it.
I think that may a good idea to check the SMPS moudle for 12V output and the following reg. ICs have the match voltage.
Good luck
Good luck
This thing looks like it was designed by a child.
I will also look at the small smps card, it remains constantly under tension and degrades faster than the rest.
Oggi, unless you maintained a membership with hifi engine, you may need to ask one of the members here to download that manual as they no longer allow new users. There is a thread running at the moment discussing this. Cheers, Stuey
I have membership. CheersOggi, unless you maintained a membership with hifi engine, you may need to ask one of the members here to download that manual as they no longer allow new users. There is a thread running at the moment discussing this. Cheers, Stuey
I also have an old account, I didn't have access to it for 2 or 3 years but I kept trying... sometimes... and one day I got my access back without any further action.Well done. I forgot my 20 year old password and that was that! No access.
- Onkyo RZ840 dead. Not turning on
