I need help deciding on a digital audio to analog converter
Thanks for all the replies. My apologies for not being clearer about the DIY aspect. I have indeed put together kits over the years, years ago I built a Haffler DH220 power amp from a kit. I even have a great electronics kit with soldering station.
But my intent is to use a simple device to solve this.
Regarding the SMSL SU-1 decoder, I didn't notice anyone mention what those output connectors are on the rear of the unit. They look like what you would plug a 1/4" guitar cable into.
If those are rca connectors, then the photos aren't taken very well. An angle view would have been better.
I recently replaced my main DAC with an Xduo MU604. This has three inputs, optical, S/PDIF and USB. Outputs are both balanced and unbalanced. This is a big step up in quality over my much older DACs and current pc audio outputs.
I also have the Prozor DAC mentioned above and is ideal for TV audio which is where mine will probably end up and for the price it is really very good.
The SMSL SU-1 only has RCA outputs. The SMSL D-6s has RCA and balanced outputs.
