I've just purchased a pair of Leak 202o Speakers to go with my Leak 2000 Turner/Amp
This may seem a stupid question, but how do I remove the front grille? I've tried using plastic pry tools normally used on mobile phones, but I don't want to use too much force and damage the metal surrounds or grille clothe
I've searched the forums, but all I can find is threads dealing with the drivers, almost as if the grille removal is so simple it doesn't need a comment
Thanks in advance
Andrew
Thanks in advance
Andrew
Looks similar to these, so maybe the same mounting method?
https://www.diyaudio.com/community/threads/leak-sandwich-600-project.212632/
"They are incredibly tight fitting. My fingernails won't do it. I needed a sharp pry tool and still managed to leave slight marks on the metal trim. I've seen lots of questions on how to remove the grilles. My advice is use a stiff pick and start at the bottom to minimise visibility of marks (inevitable)."
"The metal frames are screwed to the cabinet. It is a simple thing to gently pry the grill cloth (which is wrapped around some greenboard) out of the frame. All is revealed after that."
You were correct, and I only left a very small nick on the bottom metalwork, thanks a lotLooks similar to these, so maybe the same mounting method?
