Values of air core inductors?
Is there any way to tell what the values of these air core inductors are? This is the crossover for a Vienna Acoustics Maestro center speaker.
I am planning on swapping out the tweeter, (which sounds harsh), and replacing with a ScanSpeak Classic to match my main speakers.
It is odd...the original versions of the Maestro came with that ScanSpeak tweeter. This version seems to have a much cheaper tweeter (I picked it up secondhand off Ebay a few years ago). This tweeter has the same impedance as the ScanSpeaktho, so I think I can start simple. I'd like to try a straight swap first, listen, and then adjust the crossover values once I understand what needs to be adjusted.
I plan to use my studio mic to capture the freq response.
I have a Fluke189 multimeter. Any way to run a test to find the mH values without desoldering?
10R is part of fixed L-pad. It reduces signal to the tweeters in order to match lower sensitivity of midbass
Thanks. That is what I thought.
Since it is a 2nd-order crossover, I tried reversing the polarity on the tweeter. That actually helped with the brightness (less "shouty" now), and I will leave it this way until I can model a new crossover for the new tweeter.
There's some ridiculously cheap "transistor tester" gadgets that claim to work as LCR meters as well. Or set up a computer sound card to do impedance measurements using "Speaker Workshop" or other software.
Behringer sells a measurement microphone, ECM8000. I suspect the calibration mics bundled with AV receivers are good enough, if you have one lying around. They show up at thrift stores from time to time.
The woofer inductor can be measured without taking it out, as long as the crossover is disconnected. The tweeter is shorted by the L-Pad and you'll have to pull one leg first.
Sounds good, as it may have been made loud by choice.
Wild guess: a previous owner blew the tweeters and replaced them with those cobbled-together cheapo contraptions. So the crossover might be just fine. Is it similar to the ones in your mains?
That is my theory as well. And this cheap tweeter had leads that were soldered to the crossover wire quick connects. Unlike ALL the other driver connections, which had tabs to attach the quick connects to.
I tried to put the tweeter from my main into the center, but the faceplate on the mains tweeter is like 1mm bigger than the center cutout. So it didnt quite fit. I suspect those tweeters are 104.2mm, and the center faceplate is 103.4mm. but it does look like this cheap tweeter was haphazardly attached to the original tweeter faceplate.
Quick question for all of the experts here: the Resistor L-Pad of a 2.2R and 10R. The current cheapo resistor in there is stamped 4 ohms. But VA quotes this as a 6ohm speaker. Do the 4ohm and 2.2R resistor creat the 6 ohm overall impedance for the tweeter range? Or is that 2.2 and 10 just creating an Lpad splitter to reduce current or voltage (cant recall which) to the tweeter, and my impedance is still the driver listed impedance of 4ohms?
The ScanSpeak Classic is 6oms, as is the Seas Prestige. I am now tempted by the Seas Prestige, as that is what was in Proacs, which sounded so nice in the upper freqs when I heard them long ago. And the Seas Prestige has a 103mm faceplate....
I am tempted to just gut this entire center speaker, and rebuilt it with the drivers I want and a crossover to match. And then use the clear coned woofers in a nice little bookshelf build for my upstairs TV room.
(It has been 30 years since my EE classes, and I am rusty on my circuit calc logic. Apologies).
Combine the 10 ohm resistor and dc resistance of the tweeter in parallel first.
Assume tweeter is 6 ohms. Parallel resistors combine as 1 / [1/10) + (1/6)] = 3.75 ohms equivalent.
Then add 2.2 ohms in series with that equivalent 3.75 ohms, which yields 5.95 ohms.
Reactions: jayme
Do the 4ohm and 2.2R resistor creat the 6 ohm overall impedance for the tweeter range? Or is that 2.2 and 10 just creating an Lpad splitter to reduce current or voltage (cant recall which) to the tweeter,?
Getting the overall impedance to 6 or 4 ohms isn't much of a goal in and of itself, the nominal impedance is not that important an issue in that way. Getting the tweeter level good is the main objective, working the two resistor values to function effectively with the tweeter impedance may be another goal, intertwined with keeping the overall impedance usable.
Reactions: Dave R
