1988 Amp with 0.150 vDC offset (150mV)
Here are some pics... I may remove components to reveil the values and then take some pics... Man it's cold in my garage!!! Ugh...
Thanks again you all for having a look, I realize your expertise on this stuff and it makes for a good learning experience for me!!!
Steveu, I'm considering it... Maybe with https://sound-au.com/project3a.htm
That amp does not have a LTP degeneration, a current mirror, Baker clamp(s), a Darlington VAS, a VAS CCS. So, I dunno if I would call it "Blameless". R11, R12 at 220 are asking for shoot through current. 100 Ohms would be marginal, and I would go 47 Ohms. Possibly also not shown is L-R output isolation network to prevent stability problems caused by the speaker cable... A CFP output is not my favorite because it does not cross-couple easily, one thing your old amp did well. You may also consider 2-pole compensation. Simulation is recommended.
Point is that the collectors of Q3 and Q4 are interchanged in the shown circuit diagram, leading me to a wrong conclusion.
To bring both collectors at the same voltage, 8K2 should indeed be lowered to ca. 3k3, this will prevent Q4 to go into saturation.
At the same time the offset voltage at the output is to blame to R1 and R4 being different, resp 47K and 12K.
You could replace Q1 and Q2 by MPSA14 darlingtons, that will reduce the offset to a few mV.
When doing this, C7 and C8 will have to be removed.
Hans
I hadn't spotted the positive feedback. 🙁
OP said he was working on an existing amp, so how did the posted schematic come to be? What other errors are there? Seems like a trustworthy schematic is a first order need.
I painstakingly sketched it out with a lighted magnifying lens and multimeter... Ugh... I've checked it a few times to make sure its correct.
Hans
If I try this... I have a bunch of NOS MPSA14's, remove C7, C8, Replace Q3,4 with MPSA14's. Do I need to also reduce R8 to about 3.3K?
And check bias...
Scott
