Here in Argentina, "tires" is translated as "gomas" and its main slang meaning is "boobs".I am in my early-70s and I have yet to see a "pretty" tire. Do you also seek out pretty fan belts? Door seals?? Windshield wiper blades??? Inquiring minds want to know.
Under that premise, yes, I have seen many pretty "tires"
Just not underneath a car,Under that premise, yes, I have seen many pretty "tires"
Thanks for all the wonderful product tips.
Date code is not really important as aging totally depends on how they are stored. A tire with 3 years left, may have turned bad more than a well kept 20 yo one.
I will definitely try the driving in reverse mod. Right tires gets worn sooner because of roundabouts.
I will vulcanise my wife's bicycle with grupper af acetone.
I do things, to see if they are doable.
Nope, I know this is not true both from experience and theory. I have gone through plenty of old tires. And from my education I know that the additives are volatile.
Yes and they have better UV inhibitors for those of us without the luxury of indoor parking so indoor storage is not all it used to be. Gas off or off-gassing if you prefer, is well known in almost every petroleum based product.
Tony, what the heck is with the Elbows logo?
Means you know that Im right. Date code indicates manufacture which has relevance.Nope, I know this is not true both from experience and theory. I have gone through plenty of old tires. And from my education I know that the additives are volatile.
Condition indicates roadworthyness. I've had tons of old tires too.
Not now. I just have a spare set and I would like to prepare them for storage.
Cheers!
The main point is that you can't expect them to retain 'as new' performance for many years, and how you store them will merely affect how quickly they deteriorate.
Thanks Fahey.Here in Argentina, "tires" is translated as "gomas" and its main slang meaning is "boobs".
-So BoobCream it will be😊
Here we still vulcanise old tires. They are as good as new ones if done correctly. Never heard of anyone loosing caps f om our local vulcanizer. I've seen quite a few caps next to highways here and abroad.There is a date code on all casings. Legally on all non commercial vehicles the tires MUST be replaced not repaired
within a 6 year period. There are NO exceptions and there is no such thing as NOS.
DOT and commercials casing have no limit on life but they must pass an visual inspection first then a belt scan.
I only used Good Years rating for any and all tires casing in the event of recaps. They were rated via a Triangle
Circle or Square (?) and no more than 5 years on a casing for recapping, but it can be ran out as long as it passes
a visual.
They outlawed recaps on any passenger car a long time ago. 70s maybe.
99% are from trucks that has double Axels.
Cheers!
The crew had stop the land rover because the tread blocks were banging on the wheel arch. they had come away at the tire wall end and were spinning out to reach the wheel arch.
Not really, it's not just about degraded performance. There's a lot of sidewall stress involved in just keeping the beads seated and supported. You will have a flat on old tires.The main point is that you can't expect them to retain 'as new' performance for many years, and how you store them will merely affect how quickly they deteriorate.
In case some are not understanding how retreading truck tires works, they retread WORN tires not OLD tires. Once all the good stuff has evaporated, the tire carcass is useless as a tire.
Keeping air in is a primary factor in the performance of a tyre.
Here they call them Re treads.
Because truck tires very expensive for fleets.
So easier to buy re tread. But you cannot
put them on front tires. Ask my old boss with
large Crane truck. Why I told him no Re treads
on front. long story short. He lost the Crane.
And the driver Quit. They fail often, so more suited
for axles with dual tires.
UV light is what rots tires quicker. And storing on
vehicle with weight. Will make flat spots. Storage
off the vehicle indoors will be fine. Can keep on cheap
rims with low air pressure so they dont loose shape/
get distortion from storage.
- Member Areas
- The Lounge
- Treating rubber tires
