Mark Levinson No.37 CD transport Problem (died)
Ciao Sergio, importer came back he needs a few days more, so.patience please.. meanwhile I did a complete recap on mine, and just in time as I found out. One of the elyts other output board has been leaking for a while, a time bomb for sure! Also got a new original Philips laser unit. Up to the next 20 years!!
Reactions: sergiob
Ciao Leonard.
My ML 37 has been standing still for over a year, waiting a few days is not a problem.
The mechanics that you found, is the Cdm2 pro? Mine also has mechanical problems opening and closing the drawer.
Sergio buon Giorno.
I have good news, the chip is available through the Dutch importer for €75.
Let me know if I need to order it for you.
Grazie Leonard
Hi Leonard.
I thank you so much.
You can definitely order the ALTERA chip but I would say that to be safe if you can also order the ATMEL chip I wouldn't want the ATMEL to have been damaged by the lightning too.
Let me know thank you very much.
Good Night.
Sergio.
Happy New Year to all. As you can see from the photo, the CD player has finally restarted, replacing the Altera chip, the problem now is the mechanics, it seems that there is no axis control. I suspect the chip that controls the mechanics was also damaged.
Anyone have any ideas?
Hi Sergio, I have a 37with similar problem......when you switch on the main power the display flash for a moment then nothing.....and the leds above buttons stay on....
Is there anything that I can try ?
Have you got a shematic or service manual ?
Thank you very much in advance
