Yesterday evening I connected my lovely Exotic's again to my Accuphase and listening to them 😍😍😎.
What a wonderfull driver placed into 160 liters 😍😍😎.
Very very smooth and very deep and perfectly controlled.
This is going very very nice.
Description:
Ready B.R. speakers equipped with the very expensive and beautiful full range 8 inch drivers from SEAS with a beautiful flat curve and an impressive superior depth.
This goes very nicely, deep and low with ease.
Drivers with certificate and subsequent serial numbers.
REMARKS:
MATERIAL CABINET 18mm BLACK AND STANDARD MDF.
SIDE PANELS 19mm SOLID BEECH WOOD.
BRACINGS 44x27 SPRUCE WOOD.
PRITEX 42mm DAMPING GLUE TO ALL INNER PANELS EXCEPT BAFFLE.
TECHNICAL DATA:
Driver: Full Range from SEAS type X1-04 EXOTIC F8.
Volume cabinet: 160 liter.
Sensitivity: 96 dB/W(m).
BR port (2x) 70mm diam. x 109mm length.
BR tuning @ 30 Hz.
Frequency range: 29Hz - 20kHz (-3dB). (edit)
Impedance: 4 Ohm.
Long time power 35 Watt.
Short time power 100 Watt.
Two tone cabinets.
Sleek and solidly built.
Transparent satin finish.
Built 2023
M. den Boer
Brielle
The Netherlands.
Description:
REMARKS:
TECHNICAL DATA:
BR tuning @ 30 Hz.
Impedance: 4 Ohm.
Two tone cabinets.
Built 2023
M. den Boer
Brielle
The Netherlands.
And yet you sold itSold to a new very very happy listener in Rotterdam!
Very very nice speaker!
The sound and peaceness of this speaker is amazing. 😍 😍
You can measure if you want. No problem.Do you have any measurements? 🙂
I have. And after my experience all fullrange drivers need some compensation 🙂You can measure if you want. No problem.
But Seas Excotic and FA22 is in the smoother division.
https://www.hifisentralen.no/forumet/threads/helob-the-final-en-åpen-baffel-byggetråd.67189/page-13#post-1608505
Se also the post from Nelson Pass yesterday about full range drivers and the need for taming the hot top:
https://www.diyaudio.com/community/threads/lowther.389573/page-2#post-7544276
You will have even more peace now you don't have them.
- Full Range
- I love my SEAS Exotics
