Balance resistor ratings/size for tube PSU
Put simply, I have filtering caps run in series that need appropriate balance resistors. The set up is this:
  • Two sets of two 270uF, 420V(max) caps connected in parallel.
  • Those two sets are connected in series
  • In effect, I have 270uF rated for 840V
  • Using the following formula:
  • and with the values:
    • n = 2
    • Vrated = 420V
    • Vbus = 497V
    • Imax_D_leak = 3 x sqrt(270uF x 420V) = ~0.001A (assumes no leakage in one set and maximum leakage in the other)
  • I get an Rbalance of 343K
Here's the thing, I see a lot of schematics that have somewhat similar configs. They typically use either 100K or 220K ohm resistors (Merlin's PSU book recommends 50/C, which gives a conservative 95K). Few give ratings, and they range from 1/4W all the way up to 5W.
IMHO, the nearest common value for optimal balance resistors would be 1/2W, 330K ohm. Unless I calculated wrong, or am missing something?
That is a good point, To be clear though, the B+ voltage I'm targeting is Vbus, which is 497VDC. So each balance resistor should only see roughly half that (1% tolerance resistors).
That's still not nothing. My 1/4W resistors are only rated to 200VDC working voltage. They would indeed fail at some point. My 1/2W resistors are rated at 300VDC. The max power dissipation would be about 0.2W.
Perhaps I'm just being overly cautious, since I'm deviating from the usual 220K (or 100K) I see others using.
Ok, if the B+ is only 500VDC:
Using 2W resistors, with an actual dissipation of 1W and 250VDC across each,
that would be 1W = 250 x 250 /R ......... or R = 62,500 ohms minimum.
Then I would use 100k at 2W resistors rated at 300VDC or higher.
That would ensure good voltage sharing, and bleed 2.5mA.
Capacitor leakage will be much less than that.
Reactions: middlec
    • n = 2
    • Vrated = 420V
    • Vbus = 497V
You can always do that or you can use the cosθ derivative of a coulomb charge to define leakage, and derive a bleed balance resistor value.
Even though the best approach afterwards is purchasing the caps at the same time so that they will have the same leakage characteristics.
R = (NVmax−Vb) / (0.0015CVb)
where:
R the value of the balance resistor that will be individually across each capacitor in series (in meg ohms)
N is the number of capacitors in series
Vmax is the rated maximum voltage for any one capacitor
Vb is the B+ applied to the capacitors in series
Reactions: middlec
