I’m currently going through the interesting and thought provoking conference videos of Roger available as resources on ramlabs’ website and YT where he explains a few things including how to implement a much smaller output transformer and get, nonetheless, a broad frequency response.
And in case someone is Interested in another unusual set up aimed at getting the most out of a pp of el84, with 400v or so on the plates, here is an interesting discussion on a Dutch forum concerning the cr developments Kalypso from the 1990s
https://zelfbouwaudio.nl/forum/viewtopic.php?t=20959 The owner / fixer of the amp has posted a schematic.
The Kalypso is currently my all times favorite amp in my set up (with a large diy horn system for mid/high and 2x15” in the bass).
The above discussion points to some controversial options adopted by the original designer. It seems electronicians are like politicians: they need to disagree on choices made by others…🫢😅 (leaving aside questionable improvements made by apprentice tweakers)
Would love to hear from a rm-10 owner how s/he feels about his amp. No hearsay please.
Back to the RM-10 (or its MK-II, MK-II bis, MK-II ter)
I haven't come much further and will leave it there for now (busy with another project).
But in case someone else is interested in an RM-10 inspired project: I've come accross an interesting yet afordable OPT , 16k/4R, 60W by Edcor
https://edcorusa.com/products/cxpp6...utput-transformer?_pos=2&_sid=ea83e6e2c&_ss=r
I had an RM-10MKII (not the high power - 35w version) and tried to draw up the schematic...but remember this version being nothing really different from what you would expect... sold it as I liked the Quads powered by NCore amps (I always feel compelled to watch tube amps for red-plating / runaway)
Anyway, I now have another RM-10MKII well, minus the base, but the "guts"....the circuit is a bit different than my previous MKII...This one only has 8 ohm taps only (supposedly designed for the Quad ESLs), and has a choke, and it also has individual bias pots for each tube (Fixed Bias) - my previous one had the LEDs and the Cathode resistor (Cathode Bias)...
I have not put power on it yet as it has some loose components... more later...
OK, appears to be the 35w version as I see the voltage doubler...wierd thing is it was fitted with Octal sockets on output tubes...
Looks like someone considered the el84 was overrated, changed for bigger output tubes and moded the circuit…
I just measured the impedance of the output transformers - they are 5.6k, and the 35w version used 13k I beleive...
Just may restore the standard 25w version with EL84....was hoping this restoration would be easy...
According to what I remember from posts including by Roger M, yes 13k. But I may also have read that other values were used. 12 or 14k (?)
For what it’s worth:
Here are the only (non custom wound) 13k OPT I found so far
https://fr.aliexpress.com/i/4001160839902.html?gatewayAdapt=glo2fra
The secondary has just the 8 ohm tap...I will look again, but think that is it, no other windings...
I agree someone has modified the unit for Octals....a couple components (mainly one large cap) is detatch and dangling...need to figure out wher it goes...the heater winding is AC and tubes wired series-parallel, and I beleive the bias circuit is also off this voltage...
But I cannot figure out the Doubler circuit (if it is a doubler circuit) on the power supply...
I have the 8 ohm tap only.
My last unit had Cathode bias, not fixed. A lot of components were different from what is on schematic.
Its not too special- a 12AX7 voltage amplifier and concertina, to a pair of EL84 with fixed bias. The real secret sauce is high plate voltage and higher impedance than usual output transformers.
Did you take a look at this review on the very sinilar MKII? There's a shot from underneath showing all the wiring and components, this should be enough for a start to start tracing things by eye-
Some more pics here- https://6moons.com/audioreviews/musicreference/rm10_2.html
There's also the web archive to look at his design philosophy for the original RM-10-
https://web.archive.org/web/20200727222903/http://www.ramlabs-musicreference.com/rm10design.html
From when I last worked on an RM-10 years ago I remember the center tap of the voltage doubler being used for the screen supply to the EL84s, I can't find anything else and my notes are long gone.
Yes, the review and other stuff are mentioned in the diy thread where we “met”.
I didn’t think of using web archive to retrieve something from Roger’s time. Good thought, thanks!
Yes, both screens supplies came off the doubler CT - the schematics are now posted on Ramlabs website...
Unfortunately I have the 5.6k ohm output trannies, not the 13k ohm, so no doubler needed for 700v on plate...
- Tubes / Valves
- RM-10 (musical reference) schematic wanted
