Hi all,
I have a Sony TC-200 R2R that I want to use the power supply and output transformers for a valve amp build.
Specifications
Track system: 4-track, 2-channel, stereo/monaural system
Reel size: up to 7 inch reel
Tape speeds: 3 3⁄4 7 1⁄2 ips
Wow and flutter: 0.19% (7 1⁄2 ips)
Frequency response: 50Hz to 14kHz (7 1⁄2 ips)
Signal to Noise Ratio: 46dB
Output power: 1.5 watts
Semiconductors: 2 x 2SD64, 2 x 1T22G, 1 x 1S125
Valve complement: 2 x 6267, 3 x 30M-P23
Dimensions: 404 x 380 x 227mm
Weight: 12kg
Year: 1968
People often use the TC-500.
The power supply part number is 1441-080-12
The output transformers part number is 1427-085-11
I am hoping that the opts are as good as the TC500
The speaker part number is 1502-080-12
Are the speakers the same as the TC-500 and worth using?
I was wondering about building an RH84 or Zen etc.
Has anyone used the transformers and power supply for a build?
There is further info here on hifi engine
https://www.hifiengine.com/manual_library/sony/tc-200.shtml
Specifications
Weight: 12kg
Year: 1968
Screenshot_2023-12-07-09-23-27-01_e2d5b3f32b79de1d45acd1fad96fbb0f.jpg246.8 KB · Views: 102
Screenshot_2023-12-07-09-20-44-00_e2d5b3f32b79de1d45acd1fad96fbb0f.jpg209.7 KB · Views: 107
Screenshot_2023-12-07-09-35-19-25_e2d5b3f32b79de1d45acd1fad96fbb0f.jpg214.3 KB · Views: 95
Screenshot_2023-12-07-09-35-31-94_e2d5b3f32b79de1d45acd1fad96fbb0f.jpg349.4 KB · Views: 103
Screenshot_2023-12-07-09-20-57-32_e2d5b3f32b79de1d45acd1fad96fbb0f.jpg254.6 KB · Views: 129
Have you seen this https://audiokarma.org/forums/index.php?threads/nec-30m-p23.172750/
I am not a member, so I can't see the schematic. Do you have it?
Best regards,
Erik
Best regards,
Erik
You could build something using the stock tubes, as described in the AK thread, but the transformers are not suitable for the designs you're considering.I was wondering about building an RH84 or Zen etc.
The tubes used are equivalent to the 30A5. According to the data sheet, they typically run with only 100v on the plate and OTs with a 2.4k primary and produce ~2w. Typical SE EL84 / 6BQ5 designs run ~300v on the plate and OTs with a 5k primary. Also, the stock PT heats the tubes with 30v and the EL84 runs on 6.3v.
Thanks for the replies. It looks like I have bought the wrong RTR, and I bought two of them, Doh! I should have bought the Sony TC500.
If there is a flea amp worth building are there any circuits that will work with the power supply and transformers?
Is it worth trying to do something with them and build a flea amp or sell them on?
Check if the OPT has a 4 ohm tap. If it does, then you can connect an 8ohm speaker to it and get 4.8K reflected impedance on the primary winding.
Maybe something like this simple project with PCL82s, run the heaters serially and perhaps headphones for listening. PCL82 is capable of higher B+ than 40V, so tweak the operating point for your bits out of the R2Rs.
...and lose a bit more than an octave at the low frequency end.Check if the OPT has a 4 ohm tap. If it does, then you can connect an 8ohm speaker to it and get 4.8K reflected impedance on the primary winding.
If available, try it, measure it, listen to it, then decide....and lose a bit more than an octave at the low frequency end.
Could I just use the output transformers and by a more suitable power supply?
if I did that would it give me more options or is it thr output transformers that are the main issues?
As I mentioned earlier, presumably the OTs are designed to work with the stock output tubes so their primary impedance should be ~2.4k since that's the load specified in the tube data sheet. You could use them with other tubes that work with a similar load.
But the OTs are also designed to be used with tubes that only put out ~2.1w max (@11% distortion) so they won't be suitable for tubes that put out much more power than the stock ones. Any alternative tube that might work will require you to use a different power transformer and will only make the project more expensive.
Your best bet is to use the tubes it's designed for as was done successfully in the link in Post #2 above. Then you can also use the stock power transformer. There's no reason why you can't build something decent using what you already have.
- Tubes / Valves
- Sony TC-200 R2R Transformers
