Califoria Audio Lab - Aria (CD player)....problems????
HI, I purchased a used California cdplayer model Aria (with valves), I think it is the MK1 version.
I have some questions.
Inside there are two LEDs, one LED turns on after you hear a clickKK... I assume one or more relays switch , the other LED never turns on. It's normal?
Do you know where I can find documentation regarding this device? User manual, service manual....
Some other questions, of secondary importance:
What is the "CM" function button for? See image with yellow arrow.
What is the "FTS" function button for?...see image. When I push this button the relevant LED starts to flash. If I push the button again the LED goes back off.
I attach some images.
Thank you
