Small full range closed back vs open back without enclosure effect on audio
It's a 4 ohm full range driver which is crossed high with a 3.3 uF capacitor.
I don't think there is much to worry about regarding cancellation in this instance.
You say the sound is good, so I would simply sit back and enjoy it.
Placing a resistor of just a few ohms in series with the 2.5" driver would make it less "loud".
2.5 inch speaker back side pic
Have attached two pics can I just glue my speaker to 4 side of case or will it be some problem like due to vibrations distortion or something or is it safe
If not safe i thought of second option were i took a plastic leg I can clue it to body then place speaker on it
What do you guys suggest?
I will use glue gun but should the tweeter be in air or should I glue the magnet to bottom and 4 sides of tweeter to body were we have screw holes
Or just I use some legs one glued on cabinet and other on tweeter screw hole
Which option is good ?
I see now how the original 2" closed back tweeter was mounted. It had two mounting lugs that were screwed to two plastic mounting points on the enclosure, one of which is now broken (your photo of the original 2" tweeters is attached for illustration purposes).
If fixed "in air", the replacement "tweeter" it is more likely to match the position of the original tweeter rather than be located deeper into the recess, but I wouldn't wory too much about that. It should be sufficient just to ensure that the 2.5 inch "tweeter" is glued in place in whatever way you think is most secure.
Reactions: Kamranbits
It too was mounting it best way and secure but I come across this lines
("To prevent interference between the tweeter and woofer in your two-way bookshelf speaker, placing the tweeter in the air might be a better option to avoid direct contact with the surface that might transmit vibrations. You could use a mounting bracket or some sort of elevated platform to position the tweeter above the woofer's potential sound vibrations. This can help reduce the likelihood of interference and distortion in the tweeter's sound caused by the vibrations from the woofer.")
This is something to take care or should I just mount the secure way
Galu,
Thank you for your generous help and expertise. Your guidance has been incredibly valuable in aiding my decisions. I truly appreciate it! 🙂
You are most welcome.
I'd be interested in knowing where you read that quote, but it's true that a tweeter can be isolated from the enclosure to reduce the effect of vibrations transmitted into it by the woofer.
Isolation can be as simple as installing a soft, flexible gasket between the tweeter and the front of the enclosure, but that's not possible in your case.
Elevate the tweeter if you like, the important thing is to make sure it is secure.
An insecure mounting will mean the tweeter chassis is more likely to vibrate, and we don't want that!
