Using 2 identical full-range drivers per speaker
Im new to speaker design. I’m looking into using 2 identical full-range drivers on the same ported speaker box. I’ve seen a design where the 2nd driver just runs as a low frequency driver (using a filter). Would it be possible to have both drivers running full range, would that be advised/make sense? Thank you
dave
Well, at least you know what you are getting into, I did not.
Can you step up to a 5-6" ?
I had luck with 4 x 3" tg9 drivers frame to frame.
At 10', keep your ears between the top and bottom drivers though.
At 16', you could be a bit above the top driver....................
Reactions: GM
addendum: I've done this with three pairs of the same alnico 6x10 vintage drivers using both baffle-step low-pass inductor and side-firing mid units; high units open-baffle. Right this minute, I'm listening to 5&10 (five-and-dime) Markaudio MAOP5(gen1) OB in series with side-firing Alpair10(gen3), kind of bipole configuration. I rescued the damaged 5 yesterday from "idle-fishmarket"; the experiment sounds... jaw-dropping.
I've used two identical full range drivers in one enclosure on 4 pairs of speakers, I just wire them in series and use a shunt capacitor (about 1.5 uf seems enough) on the lower one. I've even used 4 identical drivers arranged in a square with one cap.
Reactions: GM
It really needs to be bigger than that. 1.5µF on an 8Ω driver will be above the midrange.
Using the nominal bafflestep -3dB as a staring point then: C = 1 / 2∏Rdriverfbs.
4Ω driver at 500 Hz is an 80µF cap.
And it should be below the quarter wavelength of the centre-to-centre of the drivers.
dave
Not in this physical reality.
It can work insofar as you can (can) run twin small wideband drivers unfiltered, but how well it works it depends on the on / off axis response of the drivers, their spacing and the listening position relative to them. To put it another way: there will always be some destructive interference. It's just a question of how much / how bad it is. Without knowing what the drivers are, this is all pure speculation.
