A DIY vinyl turntable many years ago
Very nice work!!! I built this TT 15 years ago.
You don't need a lot of torque when the platter is up to speed, but with a really low torque motor you may need to help the platter get up to speed manually. Generally the reason for a low torque motor is to reduce motor noise and vibration to an absolute minimum. Any AC motor with permanent magnets in its construction will have some vibration, although multiphase motors tend to be better. With DC motors the smoothest type has an 'ironless' rotor, but DC motors tend to suffer from longer term speed drift, though this can be eliminated by the use of a feedback loop.
My personal favourite is the Papst synchronous Außenläufer motor, driven by a 3 phase supply. When driven like this there is effectively zero vibration, and the external rotor provides a high moment of inertia.
Im still researching Im guess motors from the midd 90ies were of the highest quality. I dont even know if its the motors from video head, drive or eject mechanism which are good for turntables😄
Cheers!
HI,
!5 years ago when I made my second DIY TT I used a 5 Inch floppy disk motor taken from an old PC, they are brushless type, pretti silent if bearing still ok and have great torque as well. To improve then you may replace the bearing with a bronze bush. They have a good electronic speed control as well. Pity now not so easy to find them. My TT platter is about 5,5 Kg including the puc and reach the set speed well, have a torque higher than a Lenco L75, I use 3 belts to drive the platter , but also with one belt is running very well. Motor is separated from the plinth.
Rgds
Adelmo
