Is the CS43198 a same fake?
Which dac, which preamp? No need to show ES9038Q2M as that is not the topic.
There was same 9038d6k, Cosmos ADC, no preamp.
You're right about ES9038Q2M 12.5MHz MCLK noise shaping but it's hump is about 20dB lower compared to CS43131. Ok, it's not the topic.
Due to very low noise floor of CS43131 I see no reason to measure without preamp.
Setup: REW Gen 1kHz Sine@-60dB - USB ISO - Meizu Hifi DAC - Cosmos Scaler +26dB - Cosmos ADC - REW
Unweighted DR = 129.1dB [20..20000Hz]
A-weighted DR = 131.4dB(A)
The TD+N numbers on those indicate that there is a noise issue although the noise floors look quite good.
The best TD+N here is -91.4dB. The mentioned my "real DR" measurement -110.3dB is very much better. Also, all IMD measurements contain many harmonics, so TD+N does not reflect the noise level well.
I don't see any reason to check this, but if I reduce the IMD signal by 20-30dB, the noise floor will change in the same way.
so nothing new here
I have never seen comments in reviews that devices based on the CS43131/CS43198 do not sound the way a dynamic range of 130dB should sound.
To my ears, the CS43131 (meizu hifi dac) sounds significantly worse in range than the es9038q2m (e1da 9038d6k). And on the other hand, I cannot distinguish this CS by ear from the es9281 (hiby fc3: THD+N -102dB, DR 118.5dB).
Just for comparision:
This is the multitone measurement of the Meizu Hifi Pro Dac. This is the device nick_I tested:
index.php
and this is the multitone measurement of Tanchjim Space:
index.php
Contrary to the Topping D30PRo the iFi GO Bar dosen't use DSD noise shaping with PCM streams:
So some dacs use it and some not. Is this due firmware/register settings?
Not exactly. My device is not Pro but it means nothing without load.
ASR measurements of both Meizu is too noisy.
This FFT was taken for me by one guy from e1da discord channel:
You're wrong about iFi Go Bar. Here you can find some wideband FFT with similar noise hump.
I can't answer for sure. As CS43131/CS43198 have a LPF "by design" the answer "no" is more likely.
Sorry, I can only trust the measurements at ASR because Amirm tested hundreds of devices in the same way, at the same place, with the same equpment etc. It's not about to get absolute numbers but the ability to compare the devices among each other. And at ASR the E1DA with ES9038Q2M scored worse than the best dongles with CS43131. In general you can only compare devices and not the dac chips itself.
Sorry, but as I said before in this case ASR measurements are flawed as they failed to notice the noise behaviour of CS43131 with IMD. IMO this is a prime example for those who argue that ASR measurements have little to do with how the device sounds.
I understand your position, but these conditions are very far from ideal. For example, how could information about the behavior of a dongle on someone else’s noisy USB host be valuable to you? Therefore, comparison of results is sometimes not correct at all.
But my topic is not about comparison, but about the fact that standard direct measurements of devices on the CS43131 cannot be completely trusted.
By the way, similar technologies (DRE) appeared in ESS chips. This is alarming.
