Topping E70 SMPS part (IC) identification
Hello guys!
I need some help.
SMPS regulator on the picture is from Topping E70 DAC.
The SMPS IC converts 5V to +/- 5.6V, which feed the analog part of Е70.
Its manufacturing marking, evident from the photo, is something like DP0 3U7.
Do any of you have any idea what IC is?
It uses 2 ea. 4/78uH inductors for the converter, that's sort of standard.
You may be able to search in a place like Mouser for 'dual boost converter',
eliminating step by step based on # of pins etc.
Did you break it?
Jan
Thanks!
Everything is OK, it works normally, but I want to know what the characteristics of the IC are, and check if Topping did a good job implementing this IC.
Ivo
