2023: State of the art in plastic films? What do you use these days?
I'm keen to do a bit of a survey here - what do you like and use for your plastic film?
Are we as a hobby all over the map or are we, perhaps, mostly using the same one or two products? Has any kind of consensus formed on what "the good stuff" is?
Thank you.
Depends on... if you want high strength and low elasticity and low mass, it is polyester (mylar).
If the mass does not matter so much and you dont´ want to play higher frequencies than a couple of kHz then there is many more options.
Like:
  1. Nylon
  2. PPS (polyphenylene sulfide)
  3. PEEK (polyetheretherketone)
  4. PEI (polyetherimide)
  5. PAI (polyamide-imide)
Reactions: Tenson
You want high tensile strength. Low mass. so typicaly between 3 and 5 um thick for treble.
Other factors such as non hygroscopic = not polyamide (nylon) . It should be quite easy to apply coating so "fat" surface polymer is not so suitable.
Mylar is fulfilling all requirement i would say.
I like kapton for planar magnetics because of the risk that the conductor will heat up and affect the plastic. I’ve combined kapton tape with stretchable plastic as a sort of surround in order to lower the driver’s resonance frequency. For electrostats I’ve always used Mylar.
Few
Few
Oops…I meant to write ”reduced risk that the conductor will…”. Sorry about that. Kapton tolerates high temperatures well—that was my point.
